New LR4 build
Hi all,
I started my build about 2 weeks ago. I’m in Europe, so buying and shipping from V1 is troublesome/costly, so this is all self-printed and ‘locally’ sourced (mostly Amazon UK).
I have an Ender 5, which worked great for printing, no real issues.
I’ve printed the XZ plates for now, I may try get them cut locally in alu or get the LR4 to cut them if I can get it to do that.
Pain points so far:
  • M2.5 machine screws with T8 Torx heads - I didn’t have a T8 bit
  • M3 machine screws with allen head, but very tight and pokey with an allen key
  • Generally quite tight and pokey, small black screws with black printed parts, with bad eyesight is a bad combination, lots of cursing
  • I bought 6mm timing belt and 6mm pulleys by accident, the joys of DIY sourcing means these mistakes can happen
  • Some of the retaining nuts spinning were annoying, I used glue (plus baking soda) on the wheel attachments, but also nearly glued the screw in place also, thought I would have had to re-print at one stage
  • I’ve ordered the board from Elecrow, Day 10 waiting for delivery, probably into Christmas delays now at this stage also
Still to do
  • figure out the wiring, lengths/extensions, board, soldering, mounting etc etc
  • cut struts, and think more about the XZ plates
  • figure out a table, planning to bootstrap a torsion box table with some sheets on the floor
Fun so far
Tom
Build looks really great so far. You learn from your mistakes. The LR4 was the third, fourth and fifth CNC that I build from V1, the first being the Primo, and even on the third LR4 I messed some things up. That’s life. :smiley:
You’d need to go with option B if you wanted to honour the license. :slight_smile: Also, it’s not much more expensive to just order the board and plates from Ryan including shipping than to order it from Elecrow and source the plates yourself.
Having used my LR4 with ply endplates up until very recently, I would not have been confident trying to use it to mill aluminium. Even less so with printed plates, though PLA may well actually be better? I’ve not got a good enough grasp of the forces involved to say. Lasered ply just “felt more proper” :sweat_smile:
EDIT: Oops. Did not mean to thread necro I misread the date… Apologies…
