New jackpot board, x axis not working
In preparation for the LR4 release, i am already gathering some material.
As i am from EU, i bought a jackpot board from Elecrow.
I flashed FluidNC and installed the config of the LR3 to test
(FluidNC_Configs/LowRider CNC/UI V3 LRCNC at main · V1EngineeringInc/FluidNC_Configs · GitHub )
I can jog all steppers except for the X-axis.
I tried the motor on another driver and the motor works, also the driver in another slot works as well …
Any suggestion for trouble shooting ?
Google Photos
Run $SS in the terminal that tells us more relevant info.
$22=1
$21=0
$20=0
$102=200.000
$101=50.000
$100=50.000
$112=1200.000
$111=9000.000
$110=9000.000
$122=80.000
$121=200.000
$120=200.000
$132=300.000
$131=2440.000
$130=1220.000
$10=1
$30=0
ok
When i jog the X, it gives feedback in terminal, but stepper is not moving
$J=G91 G21 X+100 F1000
ok
<Jog|MPos:7.720,0.000,0.000|FS:1000,0|Ov:100,100,100>
<Jog|MPos:24.380,0.000,0.000|FS:1000,0>
Shaft of the X motor is not ‘locked’ while the shaft of the other motors are
$SS
You did $$
I should learn to read better :wink:
$SS
[MSG:INFO: FluidNC v3.8.2 https://github.com/bdring/FluidNC]
[MSG:INFO: Machine LowRider]
[MSG:INFO: Stepping:I2S_static Pulse:4us Dsbl Delay:0us Dir Delay:1us Idle Delay:255ms]
[MSG:INFO: User Digital Output:0 on Pin:gpio.26]
[MSG:INFO: User Digital Output:1 on Pin:gpio.27]
[MSG:INFO: Axis count 3]
[MSG:INFO: Axis X (0.000,1220.000)]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:0 CS:NO_PIN Step:I2SO.2 Dir:I2SO.1 Disable:I2SO.0 R:0.110]
[MSG:INFO:  X Neg Limit gpio.25]
[MSG:INFO: Axis Y (0.000,2440.000)]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:1 CS:NO_PIN Step:I2SO.5 Dir:I2SO.4 Disable:I2SO.7 R:0.110]
[MSG:INFO:  Y Neg Limit gpio.33]
[MSG:INFO:   Motor1]
[MSG:INFO:     tmc_2209 UART1 Addr:3 CS:I2SO.14 Step:I2SO.13 Dir:I2SO.12 Disable:I2SO.15 R:0.110]
[MSG:INFO:  Y2 Neg Limit gpio.35]
[MSG:INFO: Axis Z (-300.000,0.000)]
[MSG:INFO:   Motor0]
[MSG:INFO:     tmc_2209 UART1 Addr:2 CS:NO_PIN Step:I2SO.10 Dir:I2SO.9 Disable:I2SO.8 R:0.110]
[MSG:INFO:  Z Pos Limit gpio.32]
[MSG:INFO:   Motor1]
[MSG:INFO:     tmc_2209 UART1 Addr:3 CS:I2SO.19 Step:I2SO.18 Dir:I2SO.17 Disable:I2SO.16 R:0.110]
[MSG:INFO:  Z2 Pos Limit gpio.34]
[MSG:ERR: X Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:INFO: Connecting to STA SSID:demast]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connected - IP is 10.11.12.174]
[MSG:INFO: WiFi on]
[MSG:INFO: Start mDNS with hostname:http://jackpot.local/]
[MSG:INFO: Probe gpio.36:low]
ok
You have no driver on your X axis according to the board.
I think Ryan recommends staying with the V2 firmware, it might help.
That is an odd one. Best I can say is pull off the little black socket headers, I have seen the pins crossed up in them and shorting. Since you already verified the driver and stepper I have to assume the socket. The chip also powers the Y and Z sockets so it should be a header pin. Takes a bit of fiddling but you can bend them all in line and put the header sockets back on. Should be easier than returning it and waiting.
Or, since you are in the EU, don’t do that and exchange the board. If you pull of the socket headers etc. you lose the warranty. :stuck_out_tongue:
Thanks !! That worked … even though it really did not look bad … but still, after reinstalling the headers it works :slight_smile:
Google Photos
So next step while waiting for the LR4 release , making a fluidnc pendant.
Awesome!!
I am not sure if it is a header issue or if putting the drivers on kinda wonky moves them. I ship all my boards out fully assembled and have not seen an issue since.
LR4 is coming along…looking real good!!!
:wink:
I saw this on instagram and honestly thats just mean… :laughing: :laughing: :laughing:
Viscious. The LR4 is a beast.
