dos
(Daryl)
December 14, 2025, 5:26pm
101
So it’s not a jogging problem, it’s a connection problem of some sort. You’re not getting responses to any of your commands in the screenshot above. $SS for instance should have given you the startup log.
Are you positive that Windows isn’t changing back to your wifi connection that has Internet access? …the default behaviour of Windows.
thestorm
(GaryK)
December 14, 2025, 5:27pm
102
I’m sorry, I don’t know what the console is. I’m looking at the dashboard and don’t see anything that is labeled, Console
When you restart your machine do you hear the steppers engage, are they locked, you cannot move the core after start, correct?
dos
(Daryl)
December 14, 2025, 5:30pm
104
You posted a screenshot of the console output a couple posts above, showing the $G, $SS and jog commands.
Can you please confirm all of the below:
You’re reloading the WebUI dashboard each time you reconnect to the Jackpot wifi.
Your computer isn’t switching back to your Internet connection wifi automatically.
That you’re not using incognito mode in your browser. I notice that your screenshots look like you were way back in post 61.
thestorm
(GaryK)
December 14, 2025, 5:31pm
105
I really don’t know. Does this statement still mesh with your connectivity comments?
For example, in Y- I can jog in 1, 10 & 100. In Y+, I can only jog in 1, not 10 or 100.
thestorm
(GaryK)
December 14, 2025, 5:33pm
106
That is correct. Without power I can move the core. With power, the core is held in place by servo power
dos
(Daryl)
December 14, 2025, 5:34pm
107
Don’t know about what?
GaryK:
You said in post 98 that it didn’t jog when you commanded the four Y+ jogs and three Y- jogs.
thestorm
(GaryK)
December 14, 2025, 5:37pm
108
Another dumb question. You mention post numbers. Where are post numbers shown? I don’t them anywhere?
address bar. this is post 108
well was supposed to be 108
thestorm
(GaryK)
December 14, 2025, 5:38pm
110
I told you it was dumb, I just found it
i do not ever remember anyone having a problem where they could only step one mm at a time. I am at a loss!
thestorm
(GaryK)
December 14, 2025, 5:45pm
112
I closed all connections, then connected again.
For the jog buttons that work, it posts the command on the console and the axis moves as expected.
For the jog buttons that don’t work, no command is posted on the console
folks, what is the command that shows his endstops, is it $$limits
Garyk, please do the $limits what and copy and paste output here, not screenshot
thestorm
(GaryK)
December 14, 2025, 5:50pm
116
I just tried to home Z and it crashed hard into the limit switches and stalled, I had to quickly unplug it
Jonathjon
(Jonathan Jones)
December 14, 2025, 5:52pm
117
Type $limits into the console and then manually test each limit switch. That is a live view of the switches so it should show up on screen with each one you hit
Also when you reset your machine, did you edit the yaml, or did you put Ryans undedited config in?
did you put this together yourself or did someone make it for you? the endstops have 2 positions and it is very possible right now yours are backwards
thestorm
(GaryK)
December 14, 2025, 5:59pm
120
Yes, when i go to $limits, I can see all 5 switches being activated
