Update:
I finished wiring steppers and did a motion test with repetier-host, all good! I had to flash to the dual endstop firmware first [since I got the full Rambo to use it], and it seems to have worked. Next up, end stop wiring and mounting.
I do have two questions about the dual endstop firmware.
- The M666 settings, is there no way to write that to the firmware w/o editing .h and re-flashing? I know I was able to adjust my z-offset on my printrboard (marlin based) and write the setting into eeprom (M212 to set, M500 to save).
- I captured the log of starting up with the marlin that shipped with the Rambo board from here, and then again post upgrade and there are a bunch of echo lines missing. Is this expected and is there anything alarming in my console log?
Thanks!
These are the lines that didn’t log once I’d flashed dual firmware. Attached is raw dual output.
22:17:17.123 : echo: G21 ; Units in mm (mm)
22:17:17.123 : echo: M149 C ; Units in Celsius
22:17:17.127 : echo:Filament settings: Disabled
22:17:17.127 : echo: M200 D3.00
22:17:17.127 : echo: M200 D0
22:17:17.128 : echo:Steps per unit:
22:17:17.132 : echo: M92 X100.00 Y100.00 Z400.00 E100.00
22:17:17.132 : echo:Maximum feedrates (units/s):
22:17:17.136 : echo: M203 X120.00 Y120.00 Z30.00 E25.00
22:17:17.137 : echo:Maximum Acceleration (units/s2):
22:17:17.141 : echo: M201 X400.00 Y400.00 Z200.00 E2000.00
22:17:17.141 : echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
22:17:17.144 : echo: M204 P400.00 R3000.00 T400.00
22:17:17.148 : echo:Advanced: B<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> J<junc_dev>
22:17:17.148 : echo: M205 B20000.00 S0.00 T0.00 J0.00
22:17:17.149 : echo:Home offset:
22:17:17.149 : echo: M206 X0.00 Y0.00 Z0.00
22:17:17.152 : echo:Material heatup parameters:
22:17:17.152 : echo: M145 S0 H196 B92 F0
22:17:17.152 : echo: M145 S1 H240 B110 F0
22:17:17.156 : echo:PID settings:
22:17:17.156 : echo: M301 P17.98 I0.98 D83.62
