Hi Guys,
During the past days, I made a few tests of giant 3D prints with my MPCNC,
I really love this, it is so fast… That’s amazing!
First, I made an adjustable spool and vacuum hose holder, with a broken thing that I luckily salvaged from the trash:
[attachment file=93067]
I will improve this thing during the next days, so that I can run the filament with as little impact as possible on the Z axis.
Then, I made a first test part, to check that the MPCNC was able to print long flat parts without problem.
After a few failed attempts, due to a wrong bed calibration and a weak power supply unable to maintain the heat, I eventually got it right:
[attachment file=“93068”]
The part is 250 mm long and about 100 mm wide for 10 mm high. It took only one hour and 20 minutes to print it, at about 40mm/s. I ran the first layer extremely slow (at 20% of the speed), so this whole time could be reduced quite a lot, maybe to one hour or so. I think it would have taken 6 hours at least with the delta.
The result is not too bad, actually I’m pretty satisfied with how it turned out.
The only big issue is warpage, the part is not flat, so I was suspecting at this point that a bed heating system was required. The layer adhesion was correct on this part, but it could be better, I find the piece weaker than a similar one made out .4mm filament (I haven’t made any scientific test yet to check the validity of this assumption though).
The thing is that with a 1.2mm filament, you need to crank up the temperature quite a lot. I usually print at 205-209 degree C with a .4 nozzle, but for this part I was running at 225 degree. In my opinion that was not enough, I will try to go over 230 degree on next prints.
Then I wanted to make something really big and tall.
I decided to print a “vase”, of 200mm diameter for 200mm high.
the bottom is 3 mm thick and the sides are 2.4mm thick (2 perimeters).
The bottom took about 1 hour to complete, but once the bottom was done the rest went incredibly fast. I had to stop around 2h40 of printing, because it was too late and I wasn’t confident enough to let it run overnight, but the result was already quite impressive. I stopped it at around 65% completion or so. It would have taken another hour to go to 200mm high.
[attachment file=“93069”]
[attachment file=“93070”]
[attachment file=“93071”]
This print showed me a few things:
-Warpage is a big issue with big prints on a cold glass. I don’t think it can be solved without a bed heating system or a very powerful cooling system. I will first try to upgrade my cooling with much bigger fans, but I’m pretty sure I will have to build a heating system in the end.
You can see that the part left up a lot from the glass:
-Layer adhesion is not satisfying. The print delaminated at several places, I had to use superglue during the print to keep everything in place at least 3 times. I’m not sure yet why this happened. The root cause could be the warping or maybe a not high enough temperature or many other things. This will need investigation
-I need to find a better way to feed the plastic wire, it pulls on the Z axis, which made the printing results inconsistent depending on which side of the vase I was looking at.
-Retract settings will be very hard to get working. The nozzle has a tendency to ooze quite a bit due to its size and priming operation takes a bit too much time, sometimes not being finished at the beginning of a new path or missing steps due to the high speeds (there’s little torque left at high speeds).
In the end, I still find the result awesome. I don’t know how long this would have taken me with the Delta, but probably something like 12 hours or more. It only took 2h20 which I find super impressive.
I’m really pleased with how this turned out. I think this demonstrates that having a tall Z axis is not a fatality and that it can still work pretty good, even at decent speeds (I was running it at 40mm per sec). The side of the part that was not impacted by the Z axis pulling the wire came out perfect, with no visible Z wobbling.
Things I need to work on:
-the wire feeding system
-Infill overlap setup
-extrusion multiplier setup
-find the perfect extrusion temperature
-Think of an easy way to heat the bed
-Try to improve part cooling
-Fine tune my bed leveling
-find a good retract/prime combination
See you next time for more adventures!
