https://www.youtube.com/edit?o=U&feature=vm&video_id=5Zt0ztJfinw
How do you manage the 4 Motor and what program you use to create code g
I just unplugged the Y axis, and used that for the 4th motor.
I used Fusion for the egg, but I any cam could have been used, as long as your model is rotational uniform. See attached stl.
For the engraving I used F-engrave, where I scaled the image in the y-axis to account for the gearing.
I’ve uploaded the stl file to thingiverse instead.
well if you knew you disconnect the Y-axis, and you connect the 4 Motor
Now you just need to figure out how to do this!!
Loop the video…
Uh, that looks like it’s using at least a fifth axis…
It is. Milling turbine blades.
