Hi,
I have read through all the other problems the guys have posted on this topic and I still cannot get a good print. I have tried several prints with higher temp and many of the recommendations, so I am stuck.
I have a new Creality Ender 3 S1 and I am using the Creality slicer.
Actually… that profile is highly useful. It allows access to the grub screw on the drive pulley.
Some observation things:
Cura slicer is probably better than the creality one. Just MHO.
Infill should be rectilinear of some other structural infill. I like Cubic Subdivision
You have very think walls and top bottom. That profile becomes a solid block at those numbers and may not be as strong as designed. Use Ryans suggested numbers and try it out.
Might be printing too hot. I usually print at 200-205.
Hi Mike,
Thanks for the advice. I will give your suggestions a try. I am using the Creality slicer which came with my Creality Ender S1 which I bought two weeks ago. All other parts of the MPCNC have printed perfectly even the Core. 2 days and 3 hours. Quite a marathon, but well worth it. It looks like a work of art.
