Marlin was restrucured. Some folks have reported issues with errors associated with a filename being too long. There’s a fix for this described in the how-to instructions on the Firmware page - look for “Beta Pre-Release Firmware” and remember to close the IDE before you save the changes to the preferences.txt file. Good luck!
Yes I have been to the GitHub page and downloaded the Dual Endstop that I required but leading back to my first post, its not in a structure that the usual MPCNC firmware that I am used to is in.
Ok thanks to BT I have got the new software installed and running on my MPCNC.
Is there a lot of changes between the older version and this one as I have done some test runs and what it is drawing well it isnt even recognizable to what its meant to be drawing, I am assuming I have just missed a setting somewhere. I had to change steps to 160 as I am using 20 Teeth pulleys instead of 16 Teeth, but I cant remember if I had to change anything else.
I would say neither the X or Y steppers are moving in the correct direction as I have no idea what it is they were trying to draw, but both directions did move and had no issues with steppers out of sync, at least when they did move they moved in tandem.
I am currently doing some 3D printing so my CNC machine isnt on, but when I have finished my prints, I will draw a simple 50 mm x 50 mm cube and see what it is trying to do.
