Mpcnc Primo to LR3 Conversion
Hello, I recently bought and built a MPCNC Primo but I built it too big so instead of downsizing I would like to know if anyone knows the parts I would need from the hardware kit from the v1e store for the mpcnc to convert it to the Lowrider 3. Thanks!
Here is the hardware list for the Primo
https://docs.v1e.com/mpcnc/PParts/#hardware
and the hardware list for the LR3
You will be short some screws but that should give you a number for how many. You might be better off (easier) to get this instead…
That is the hardware and the linear rails needed for a LR2 to LR3, this should get you what you need to go from a Primo but check and see. Your steppers and control board from the primo will work just fine on the LR3, just will need a firmware flash.
You will also need…
XZ Plates
YZ Plates (or cut your own on the Primo before disassembly)
Belt (look at the LR3 Calculator for how much you need)
2 Z Lead Screws
I’m sure I am forgetting something but hopefully someone will come along and catch my mistake LOL. You should be real happy with the LR3!
Thank you!
