MPCNC mounts for printed Jackpot case?
I’ve printed this Jackpot case for my MPCNC. The board’s installed, cables are in a good spot, it works great. The only thing is I don’t know how I can mount it anywhere on my MPCNC.
I have an aluminum bar installed under my MPCNC’s tabletop that juts out to the right. It’s secured by brackets under the table, and it used to support the 3D printed SKR Pro 1.2 box that I was previously using. The Jackpot case looks like it has an opening to hang on a similar aluminum bar or other mount that goes upwards at a 45 degree angle. My bar is 0 degrees, parallel to the tabletop.
Is there some kind of mount or solution I can use to safely and stably mount the box? I’ve got a few thin shims wrapped in electrical tape that are at least serving as a temporary anti-skid measure but it isn’t permanent. I don’t mind doing some kind of different mount for the aluminum bar, or some other solution that involves further futzing and drilling into the underside of the table.
Ryan did create a holder, I am not sure whether it’s on printables though or somewhere in this forum.
Closing older topics, to fight spambots
