Canada build space saver table 36 x 60 printable surface. short table is 15 x 44 and long table is 60 x 44, so far everything is holding up good .
I’m looking to build a space saving table as well. I hadn’t thought of folding table legs. Are they stable enough?
Yes- very stable and I can stand on it and I weigh 200 pounds
This is an awesome idea. Glad to see stuff like this, nice work figuring it out and executing.
For larger tables you want to flip them on a longer side as most spaces do not have ceilings high enough to stand up 9+ ft rails.
I am currently building a table that uses the same basic design from this thread
yes, I went with the short side because I have high ceiling and less complicated with the running of the belts for the Y-Axis to travel on .but so far I really like it .
but your looks awesome too
Nice table.
How high off the ground is the hinge point?
I’m looking to do something similar, but have it contained in a 5’6” wide by 23” deep doorless closet in my wood shop. The header is 83” high so I need to take it low. Just curious how high your is
Thanks
I used piano hinges
Perfect, thanks!
Looks like I might go for a mobile version, for flexibility, but your pics helped a ton.
