i prefer your configuration 5 drivers and direct wiring to each motor, i need my machine to be accurate as possible
firmware is Marlin-MPCNC_Ramps_T8_16T_LCD_32step_DualEndstop
regarding the sd card and encoder issue , i am waiting to my SD 10 connector TO arrive (aliexpress), i tested just to make sure with my 8 pin connector, not working.
What I found so far:
configuration.h
I would enable classic_jerk and set it to 3,3, 0.2
#define X_BED_SIZE 200
#define Y_BED_SIZE 200
this is not yur correct size, I assume. You will run into issues if you want to home from a positiob like 500 or so. Put in correct values!
uncomment:
#define EEPROM_SETTINGS
#define INDIVIDUAL_AXIS_HOMING_MENU
#define CR10_STOCKDISPLAY (and comment out reprap_discount_fullgraphics_display)
Other than that, I didn’t find any bad things.
Stepperdrivers:
The jumpers are set wrong. You have to set MS1 MS2 and MS3 for 32 Microstepping. You set to fullstep! Might be a reason for the sound.
On the sounds of your steppers, check additionally, if all wires are correctly connected to the motors. If you are missing a coil, this sounds awful!
You need to wire you steppermotors with seperate drivers using this firmware and you need to attach the second endstops on x+ and y+!
Cheers
Armin
WOW!! you are most generous person, thank you so much for investigating it.
i will make changes and update you soon, hoping for good results.
take care
it seems your solution is working perfect!!! educator for real.
the LCD issue is yet to be solved, i will wait for new connector and follow your advice about EXP2.
@arminth. Great work!
@tag.me.not Great job giving info and following through, and just as importantly, great, thankful attitude.
finally… it is a huge milestone in the project, thanks, and see you all on next issue
@tag.me.not You’re most welcome!
A very own video style!
I particularly liked the music and the cut went well with the music.
Sincerely, Pascal
Loving the editing style!
your comment is very much appreciated, thank for that. test 004 soon…
Expressing my deepest respect for the MPCNC project!!! It is amazing, nothing less.
The way i perceive it, the machine is all about increasing level of freedom and choices on global scale, a fusion of human skills: low tech craft and digital technology (CRAFTECHNOLOGY:).
The fact you (and all V1\MAKERS community) made it accessible creates positive change in cultural attributes.
Have a great weekend and take care.
That’s why I love community projects! Glad that I was able to help a little bit to enable you create something really impressive!
Have a great day and I’m looking forward for number 004! +1 subscribe!
Cheers
Armin
Dear Armin
Could not done it without your expertise!!
thank you for subscribe!!! great motivation - it will keep me on creating.
Well those previous 4 posts really warm my heart.
Need some community in there…craftmunitytech?
Yes!! sounds good to me, most inclusive terminology describing accurate, authentic and relevant state of mind.
