I have to do a milling machine project, initially the project has a working table of about 3000x2000x *** [mm]. Am I able to do it on this construction? I’m going to mill only technical foam, polystyrene foam or similar. Making molds for drones.
- Is there an example of how the supports on the x and y axes would look like?
- how high accuracy can be obtained on this device, suggesting that it will be my first time (does not expect a great value)
3.Weigh axes, we can give support but what about the internal ones? - I would like to go in the direction of such a miller rather than a plotter
- must there be some advanced equipment for milling these materials?
- If it can work, do you have any advice on what to look for in order to strengthen the constructions?
Thank you very much for every answer. I know that the idea was a bit crazy, it was not mine. I have to try it for a pass, let me know if it makes sense to do it. how big a working field did you manage to make?
I am very sorry if I repeat topics, there are a lot of topics
