MP3DP V4 - Dan Roscigno's build
Hi Folks,
I just started ordering parts. I have a bunch of stuff coming from Ryan, and 2020 extrusions from Zyltech. I have Linear rails in my cart at Amazon, but saw @barry99705 's post about LDO rails and am thinking about getting those. I am building 200x200x200, so from what I understand I need 250mm and 300mm linear rails. Would LDO’s 245mm be long enough for the 250s, or should I get 300 and chop them down with a cutting disk and an angle grinder?
As I go, I will be glad to edit a pull request in the docs repo to maintain an updated BOM building on @azab2c and other folks fine BOM work.
By the way, ignore the $12.99 shown in the Filastruder link preview; the rails are $27.99 or so.
For anyone else reading this: If you look at the rendering in Fusion 360 (I just now got it working again on my Mac) there is some wiggle room. I am ordering the LDO ones and will cut down.
Not much in the Y axis. The clearance is almost 0 front to back.
Z has a little extra room.
Maybe x too depending on where the screw holes line up.
Thanks David, I will be starting with 370mm, so I can make some practice cuts :slight_smile: I think there are only two that have to be pretty exact.
I had to cut my two y axis.
I just changed my design for a taller z so I didn’t have to cut those.
I guess with three rails, there is plenty of stability for extra height. Thanks, I will do the same.
Ended up adding extra 20mm to Z extrusion to help accommodate box containing electronics. Not sure if it’s a good idea yet, either way will share details/pics in my build thread when wired up.
Thanks, I love the idea of a place to store the electronics, spare nozzles, allen wrenches, and lint.
I ended up ordering a 24V MK52 bed from Aliexpress (blurolls is seller). Hopefully it works, https://www.aliexpress.us/item/2251832788942127.html?spm=a2g0o.store_pc_allProduct.8148356.1.8f6c6f1arnXh6u&pdp_npi=2%40dis!USD!US%20%2449.90!US%20%2444.91!!!!!%402101f49516825178665555599e8602!12000018235814844!sh&gatewayAdapt=glo2usa&_randl_shipto=US
I hung all my electronics off the back, but I can see the appeal to having them on the bottom. I just didn’t want to have to lift the printer to work on it.
These printers are not light once built.
