Mounting Jackpot3 board
I have a MPCNC where the SKR board is mounted below the base. I am upgrading to the Jackpot3 board and changing the 12V PS to 24V. I’m thinking I can simply swap it out and replace. Or, does it have to be mounted closer, such as on top of the gantry?
Mounting location is really only limited by cable length, and by antenna interference (antenna should not be restricted by cabling, metal enclosures, or solid objects)
