Mounting inserts into the tubing
Hi Folks, I built a Primo a few years ago and recently moved. I am reassembling things now. Back when I built it someone posted some 3D printed supports for the tape measure trick that are made up of a cylinder sliced on an angle that fits into the end of the conduit. A screw goes thrrough the two halves of the cylinder into a locknut, when the screw is tightened the cylinder halves lock into place. I need to print some more, but can’t find the stl file.
If anyone else remembers this, can you point me in the right direction?
Of course I found it now that I asked!
MPCNC TMT wedge anchors by gleblanc - Thingiverse from this thread:
Want to mark yourself as your own solution? That might help future searchers.
