Hi Everyone,
Sorry by advance my english is no good, i from Belgium natural language is french.
I have follow this topic before post: mks-gen-l-dual-endstops/11210
Marlin firmware: MPCNC_Ramps_T8_16T_LCD_32step_DualEndstop
All motor work correctly, but, only endstop Z right not work, i have tested M119 see result, i have signal
x_min: open
y_min: open
y2_min: open
z_min: open
z2_min: open
z_max: TRIGGERED <--- this is my endstop right Z
>>> M119
SENDING:M119
Reporting endstop status
x_min: open
y_min: open
y2_min: open
z_min: open
z2_min: open
z_max: open
My file configuration_adv and config is modified based on Teaching Tech
#define USE_XMIN_PLUG
#define USE_YMIN_PLUG
#define USE_ZMIN_PLUG
#define USE_XMAX_PLUG
#define USE_YMAX_PLUG
#define USE_ZMAX_PLUG
// Enable pullup for all endstops to prevent a floating state
#define ENDSTOPPULLUPS
#if DISABLED(ENDSTOPPULLUPS)
// Disable ENDSTOPPULLUPS to set pullups individually
#define ENDSTOPPULLUP_XMAX
#define ENDSTOPPULLUP_YMAX
#define ENDSTOPPULLUP_ZMAX
#define ENDSTOPPULLUP_XMIN
#define ENDSTOPPULLUP_YMIN
#define ENDSTOPPULLUP_ZMIN
//#define ENDSTOPPULLUP_ZMIN_PROBE
#endif
// Enable pulldown for all endstops to prevent a floating state
//#define ENDSTOPPULLDOWNS
#if DISABLED(ENDSTOPPULLDOWNS)
// Disable ENDSTOPPULLDOWNS to set pulldowns individually
//#define ENDSTOPPULLDOWN_XMAX
//#define ENDSTOPPULLDOWN_YMAX
//#define ENDSTOPPULLDOWN_ZMAX
//#define ENDSTOPPULLDOWN_XMIN
//#define ENDSTOPPULLDOWN_YMIN
//#define ENDSTOPPULLDOWN_ZMIN
//#define ENDSTOPPULLDOWN_ZMIN_PROBE
#endif
// Mechanical endstop with COM to ground and NC to Signal uses āfalseā here (most common setup).
#define X_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Y_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Z_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define X_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Y_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Z_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Z_MIN_PROBE_ENDSTOP_INVERTING true // Set to true to invert the logic of the probe.
//#define X_DUAL_STEPPER_DRIVERS
#if ENABLED(X_DUAL_STEPPER_DRIVERS)
#define INVERT_X2_VS_X_DIR true // Set ātrueā if X motors should rotate in opposite directions
#define X_DUAL_ENDSTOPS
#if ENABLED(X_DUAL_ENDSTOPS)
#define X2_USE_ENDSTOP XMAX
#define X_DUAL_ENDSTOPS_ADJUSTMENT 0
#endif
#endif
#define Y_DUAL_STEPPER_DRIVERS
#if ENABLED(Y_DUAL_STEPPER_DRIVERS)
#define INVERT_Y2_VS_Y_DIR true // Set ātrueā if Y motors should rotate in opposite directions
#define Y_DUAL_ENDSTOPS
#if ENABLED(Y_DUAL_ENDSTOPS)
#define Y2_USE_ENDSTOP YMAX
#define Y_DUAL_ENDSTOPS_ADJUSTMENT 0
#endif
#endif
#define Z_DUAL_STEPPER_DRIVERS
#if ENABLED(Z_DUAL_STEPPER_DRIVERS)
#define Z_DUAL_ENDSTOPS
#if ENABLED(Z_DUAL_ENDSTOPS)
#define Z2_USE_ENDSTOP XMAX
#define Z_DUAL_ENDSTOPS_ADJUSTMENT 0
#endif
#endif
//#define Z_TRIPLE_STEPPER_DRIVERS
#if ENABLED(Z_TRIPLE_STEPPER_DRIVERS)
//#define Z_TRIPLE_ENDSTOPS
#if ENABLED(Z_TRIPLE_ENDSTOPS)
#define Z3_USE_ENDSTOP YMAX
#define Z_TRIPLE_ENDSTOPS_ADJUSTMENT2 0
#define Z_TRIPLE_ENDSTOPS_ADJUSTMENT3 0
#endif
#endif
I have prepared shema for my board
i not found my error Can you help me please?
Thank you
