I tried the solution multiple times. I am now quite sure, that the connection Mini-Rambo to LCD board is correct, since it is the only combination where the display lights up and the lcd board's reset button issues a reset signal.
Uploading the firmware issued no problems or warning either, not on Linux and not on Windows. I first tried Arduino version 1.8.10, after that according to the solution mentioned above I tried Arduino version 1.8.9.
Following steps over all
downloading and installing arduino software
downloading Marlin-MPCNC_MRambo_T8_16T_LCD firmware from github
starting arduino and adding the link to the package_ultimachine_index.json to preferences
adding and selecting the board "RAMBo"
adding library "u8glib" in library manager
opening Marlin.ino from the firmware mentioned above
change view to "Configuration.h"-tab (4 tabs open)
connect Mini-Rambo to power and to usb port (LCD board not connected to Mini-Rambo)
select it in arduino port selection (is recognized correctly)
(validate and) upload sketch
disconnect Mini-Rambo from usb port and from power
connect LCD board to Mini-Rambo (have tried all different combination of port and orientation)
reconnect Mini-Rambo to power (12V, 6A)
Some strange messages in arduino serial montor and in pronterface, when trying to connect, as shown in the pictures attached.
I donāt know, what I should do next to reduce the number of possible problem origins. Maybe someone is able to help.
Reflashing about 20 times with no changes to the process whatsoever now worked out as planned: No more strange messages in Pronterface and other programs. The last walkthrough was with Arduino Version 1.8.10 and the steps above, without connecting the lcd board and longer waiting (2-3 minutes) before changing connections. So after āupload doneā is shown in the arduino software, I waited a few minutes, before disconnecting the Mini-Rambo from power and the usb port. Now the messages displayed are ācorrectā or at least understandable, except of some errors, but controlling the steppers works as intended, which is by far the most important part to me.
The display does still not work as intended.
Is there a chance, that I am just using the wrong type of LCD-Board? Honestly, it was a guess that most LCD-Boards with the same components (screen, knob/button, reset buttonā¦) work pretty much the same.
Is there someone using a smaller LCD-Board as sold in the shop and used in most builds? One of the size I am using (as shown on the pictures above)? If yes, is it working?
Or are there good chances, that it will work with a board like that:
Wild guess, but I think you may have configured your firmware for the full LCD, not the small LCD. @jeffeb3 or @vicious1 could certainly confirm (as could others, Iām not trying to knock anyone).
edit: The LCD you linked to is the āfull LCDā of which I speakā¦
Yea, I guess I will purchase one of the full LCDs (one can never got enough of spare parts) and while waiting for it to arrive, I will take a deeper look into the configuration.h, since there are some lines, that may be intended for the use of a smaller LCD.
Yep, that LCD is different. In the firmware, this is set: REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
If you post a link to your LCD, we might be able to tell you what steps to take to get that LCD working.
And I appreciate the diligence trying to get the flashing right, but they are really robust and if there arenāt any errors printed, then it probably worked the first time, and it takes about 15 seconds or so. When it says, ādoneā, itās actually done. No unmounting or syncing required.
The link he posted implied that itās a 2004A LCD (?) with the RAMPS 1.3 controller⦠Iām guessing this is the right course of action. (Note that I said āguessā, and that Iām not nearly qualified to actually suggest a reasonable course of action)
Thanks for your help. Because of the cryptic messages, shown in the last two pictures of the first post, I thought there was a problem with the flashing process. Wouldnāt have guessed, that these messages appear because of the wrong LCD-setting and I am still not sure about it.
However it was just stupid of me, not to look into the Configuration.h in detail, since it is extremely helpfull, very well structured and very well commented and a short look wouldāve been enough, to see quite a few options for many different displays.
The serial monitor and pronterface are maybe just the wrong baud rate? Otherwise, arduino is in German :), but it looks right to me. You definitely should ādisconnectā the serial port from pronterface before uploading, but it should be ready as soon as itās done.
The baud rate might be the correct problem source, I changed it in one of my later iterations of flashing. Although I did not change anything in the arduino settings, only in Pronterface.
I will try to recreate the problem as soon, as Iāve time and leave another post if I find out, what I did wrong and what caused the cryptic messages.
However, as edited into the older post, I am very happy that the display is working absolutely fine now, although I wonāt be able to enjoy the nice bootup-screen ā¦
