Pictures only are attached - mini-MPCNC, bearing 624ZZ. Conduit 16mm (European version
Holy cow, looks like someone got out the shrink ray! That is awesome looks great, and had to be a ton of work!
actually not too much, just your excellent design copy-pasted
If you are ok (basically it is your construction), I can share stl files. Or maybe later, when everything will be working - so far I am waiting for shipping of steppers and extra bearings.
Sure but lets wait until it has been tested, and please document it well, BOM, assembly ect.
Very cool, I have also played a bit with a scaled down version before, this one is for 18mm with 625 bearings
I only got as far as the rollers
Really my project is not old - it has been started about 10 days ago. But I am in sick leave now - I do have lot of time (but lot of problems as well).
I don’t need to build a 5th machine.
That thing is so cute though.
Finally the first test
video
OK, the race is on… Who can build the smallest MPCNC?
Hi!
Is/has someone build(ing) this version? I started a month ago printed the STL’s and started building. First I used 15mm conduit (used for central heating in Holland) . This did’nt work so I bought 16mm conduit at the Hornbach store. I sumbled over some problems:
The Z-axis lists a M8 Threaded Rod and and Bearing 608ZZ but the Shaft coupler does not fit in the nut_lock.stl
There are two roller spacers. (1mm and 2mm). Which do I use were?
Does someone published his build or has experience building this version?
Regards Tjeerd
Hi Tjeerd,
it will not work with 15mm tubes - even 0.1mm is important.
Most probably you have bad luck with M8 coupling nut - it is possible to find 2 different type in a local shop in Finland.
As option I can give sketchup file - you can modify yourself according your sizes.
About spacers - I don’t remember exactly, one type for X, another for Y, just check what is better for belt.
As I know, few people had build this machine, but I have not seen any publications.
Regards,
Vladimir
