I’m using a DIY CNC with a MAKITA RT0702C router. I’d like to move the speed control outside the CNC enclosure by adding an external box that bypasses the 620H14-7 CONTROLLER.
The idea is to keep the router speed out of reach, especially since kids will be using the CNC.**
Does anyone have a wiring diagram or suggestion for how to set this up?
Thank you, Philipp. I’m currently exploring a solution that involves Arduino-based control and is compatible with G-code generated from Fusion 360. There appears to be a viable option worth investigating."
