My observations are:
1 I didn’t follow the instructions and printed it with a lot less than 100% infill, it cracked and broke.
2 The nut traps in the MPCNC_V2_RT0701C_Tool_Holder_-_Adaptor.stl fitted plain (not nyloc)6-32 UNC nuts, not metric
3 I used 6-32 1/2" cap head bolts to fix the back cover to the adaptor, anything longer doesn’t fit
4 It was a real fiddle fitting the mount to Ryan tool holder as the mount didn’t allow clear access to the screw heads.
I am now trying https://www.thingiverse.com/thing:1955583 which isn’t as elegant but so far hasn’t fallen apart. I printed with 60% infill. At the moment I am the dust collector holding the shop vac!
I’m using this one and it works well. I think there is a version that mounts directly to the conduit and this might be a slightly better choice as long as you are not planning to try other tools like the vinyl cutter.
@denseuropa: Thank you fore sharing your experiences. It made my decision easier. I don’t want to be the dust collector my self . I decided to try the same as Derek
It looks solid and is mounting the Makita closer to the Z-rails than all other mounts I have found yet (in combination with the universal toolmount).
@zoominbc: Thank you for sharing your configuration. I thought there is no compatible dust shoe for this tool mount, with your info I made a closer look at the dust shoe you linked. At the end I decided to construct my own version with openSCAD to add some adaptations and make it completely mating with the tool holder.
My printer finished printing today! At the first sight it looks good.
How about this and the Hicwic mount? I got a Makita and printed a Hicwic instead of the 525 universal. Swapping tools is going to be a norm on my build.
Are you stiil using this makita mount and dust shoe?
Would you recommend it to others and do you by chance have you remix of the dust shoe as STL to share?
I have already printed the dust shoe and have the mount printing now. Moving on from the hicwic universal mount since it has to much flex.
Really appreciate if you are able to get back to me
