I did another test, this time to try Repetier. Everything works fine except 1 thing (in both Repetier and Pronterface):
The, in this case, drawing comes out half the size in both directions.
Does this maybe have something to do with the 1/32 microstepping?
Yep. Start by just moving it 10mm or 100mm with the manual movement buttons and measuring how far it goes.
You can change the steps with M92:
M92 X200 Y200 Z800
And if that works, save it with M500. I also make a point to go edit my firmwares default steps/mm, even if I don’t reflash it. Just to make sure I don’t forget the change in 6 months when I flash it for some other reason.
If I were you, I would take a note as to which firmware you flashed it with, and maybe even zip that up with a name like “Marlin - Flashed to MPCNC July 2020”. In 8 months, you might want to poke around with new features, or try a new version of the firmware, and knowing exactly what was on it in case you want to go back is really helpful.
You can change that setting here:
If you do change that, then if you ever flash it again, that will be the new default.
Now with the drawings I’m pretty confident. I can set my start positions and it does excactly what I want.
But in a few days I want to try to CNC with my router on some wood. I think I will test it on MDF.
But I have no clue where to start, what settings I should use.
My router is a Makita RT0700C and I have a 6mm bit with 2 flutes.
You can definitely go in full steam ahead, and just be OK with making funny looking firewood (it’s inevitable, there will be mistakes). But you might also enjoy the confidence that comes from cutting some HD purple foam first. It has absolutely no load on the bit, so you should not have to worry about depth of cuts or feedrates. When you’ve done a couple of jobs and you have a decent checklist, start easy in wood, and then dial up the settings until you hit problems, and dial them back. You’ll get a good feel for your machine this way, and you’ll understand a lot about which things are tricky and which things are NBD.
Take a look at the milling basics page. Those settings are pretty conservative, but they are for an 1/8" bit, not a 6mm. Especially when plunging and slotting, your bit will have more load. I still think those settings are a good starting place. Every type of wood and bit is going to be different. So it might be a good time to start a log of sorts to record what you tried and what happened. Get it dirty!
I could try milling some foam first.
I’ve got some left over pieces of PUR, from insulation our roof. This is 8cm thick.
That would be a good material to start right?
First, check the baud rate on the screen. It should be 250k.
After that, the serial port probably isn’t enabled in the firmware. Does the port you’re connecting it to have a number, like tx1? If so, set SERIAL_PORT_2 to that number (1, in my example).
On the tfts I played with, there was a button in the settings to change the baud rate and it started at 115.2k.
Can you post a pic of the port you’re plugged into on the mks? I will have a minute at a keyboard in a little while and I can look at the schematic to guess which port it is on.
You could also just try 1 and set the baud to 250k and try it.
