This came across my instagram! I saw I am late to the party as Ryan was already following them! Are you in our forum??
That was so 2 hours ago. ![]()
Better late to party then never bahahahaa
There’s a lot to love there - and the van has been scanned internally, I can’t wait to see what is next! Please keep me updated as I am too lazy to subscribe to an insta feed!
I will try my friend! ![]()
Reply hey Peter! He put the dust boot on printable! And the vacuum arm and something else! https://www.printables.com/@BROS_5617367
Thanks! I have checked out his Insta- and it’s pretty impressive stuff! I want to know more about the workflow for the po sheet he uses too- it looks similar to the way I use PVC.
The vac bits are cool too!
I really like the integrated belt/rail holder, feels like it makes aligning things easier (I used a jig for mine but it felt unecessarily complicated…)
https://www.printables.com/model/1899807-bros-cnc-y-clips-lowrider-v4-80mm-aluminum-profile
bros really knows how to make an entrance looking at his printables page!
You know you 2 collaborating could lead to some very impressive stuff!!!
It’s either odd or obvious, but I am exactly in the middle of doing that instead of just replacing the LR3 heat-creep affected ones - not mounted to aluminium - but for my next iteration I am considering a “frame mount” rather than a table very similar to the van installation. Aluminium is stupidly expensive here though it would be nice. - 40x80 last time I looked was around $350AUD for a 6m length!
Either great minds thinking alike, or one of those obvious afterthoughts that can happen when you don’t have to worry about how many things fit in a box!
Roll on LR4.5 is say!
Can you actually get a 6 meter length of 4080 there? Shipping would be brutal for that here in the states.
And, why would you be using 4080 instead of 4020? That would be a monster!
Misumi will offer me up to 4 meters of 4080, and it’s not terrible at $223.60 for qty 1. I’m not logged in right now with my account there but last time I checked, it would be around $1200 to ship that one piece of 4080.
The 4m length of 2040 is only $77.20, but it too has heavy shipping costs. The 2m length of 2040 is half of the 4m in price, but it qualifies for cheap shipping in the US. (Can send it via UPS). I think it tops out at around 2.2 to 2.5m for cheap shipping here.
$3.00 per cut makes it shippable! I still don’t see the sense in it though - other than convenience.
I just noticed they are using fully printed strut plates and doubling up on some of the braces, that is interesting! The printables link is neat too, hope they keep coming up with stuff ![]()
I really like the dust collection mount attached to the core, especially because it has two support points! My current mount sometimes rubs against the router, causing wear from friction and potentially becoming a safety hazard.
Do you think this mount would work with the Makita router, or would it need some modifications? The Makita has a spindle lock button on the front for changing bits, so I’m wondering if the mount might interfere with access to it.
I also noticed that the dust collection tube narrows toward the end. Wouldn’t that restrict airflow and reduce dust collection efficiency a bit?
I suspect it needs modification - but not a lot.
That depends on the vacuum in use - I am assuming that this is designed for a shopvac which has a relatively low volume high speed flow, and I stand corrected if I am wrong, but I believe that will accelerate the flow at the narrow point, like a crevice fitting on a household vac. With a shop dust extractor, yes, generally restrictions are bad.
I remember ryan having some recommandations against this
I’ve done that on one of my builds. It ends up seriously stout that way
^when you add the strut plates. On that build I used printed strut plates
Yes, torquing the core around with a dust collector mount isn’t a good idea
