Machined Air for first test, I am not sure why I missed
So while doing the standard crown test, it ran nicely, but missed the wood . I cut and pasted the standard header G-code
lLR4 jackpot board
here is the header I have probably missed something
G21
G90
G94
G92 X0 Y0
M0 (MSG Attach probe)
G38.2 Z-110 F200 P0.5 (probe down set thickness )
G1 Z10 F900
M0 (MSG Remove probe)
G00 X0.0000 Y0.0000 Z0.0000
G00 Z2.0000
(No. 1 Engraving machining: Engraving 6)
G00 X37.7100 Y11.1334 Z2.0000
G00 Z0.5000
G01 Z0.0000 F180 S10000
G01 X36.9375 Y13.7500 Z-0.9930
G01 X36.9561 Y13.7550 Z-1.0000
Are you using a probe for z?
Yes, the standard V1E touch plate. .5mm is set as the plate thickness
I ran the code again, the positions read right on the screen, but I could not get closer to the wood and not hit if I tried
Can you post the file? The original “crown” gcode starts with “G92 X0 Y0 Z0” which sets the current position to zero, and will cancel out any probing or offsets that you had set prior. Could that be it?
I generated my own in Etslcam, I will try the sample file
Sample code worked and looking closer at the test board I did make light contact on part of the cut, maybe I probed a high spot, or messed up the holding the plate down.
I am only going down 1mm and I am cutting plywood
