This is my config file -
grbl_mode true
default_feed_rate 4000 # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate 4000 # Default rate ( mm/minute ) for G0 moves
mm_per_arc_segment 0.0 # Fixed length for line segments that divide arcs 0 to disable
mm_max_arc_error 0.01 # The maximum error for line segments that divide arcs 0 to disable
# note it is invalid for both the above be 0
# if both are used, will use largest segment length based on radius
Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
alpha_steps_per_mm 160 # Steps per mm for alpha stepper - default 200
beta_steps_per_mm 160 # Steps per mm for beta stepper - default 200
gamma_steps_per_mm 4535.44 # Steps per mm for gamma stepper - default 4535.44
Planner module configuration : Look-ahead and acceleration configuration
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING
acceleration 500 # Acceleration in mm/second/second.
z_acceleration 35 # Acceleration for Z only moves in mm/s^2, 0 uses acceleration which is the default.
junction_deviation 0.05 # Similar to the old “max_jerk”, in millimeters,
# see https://github.com/grbl/grbl/blob/master/planner.c
# and https://github.com/grbl/grbl/wiki/Configuring-Grbl-v0.8
# Lower values mean being more careful, higher values means being
# faster and have more jerk
#z_junction_deviation 0.0 # for Z only moves, -1 uses junction_deviation, zero disables junction_deviation on z moves
Stepper module configuration
microseconds_per_step_pulse 1 # Duration of step pulses to stepper drivers, in microseconds
base_stepping_frequency 100000 # Base frequency for stepping
Cartesian axis speed limits
x_axis_max_speed 11000 # mm/min
y_axis_max_speed 11000 # mm/min
z_axis_max_speed 500 # mm/min
Stepper module pins ( ports, and pin numbers, appending “!” to the number will invert a pin )
alpha_step_pin 2.0 # Pin for alpha stepper step signal
alpha_dir_pin 0.5 # Pin for alpha stepper direction
alpha_en_pin 0.4 # Pin for alpha enable pin
alpha_current 2 # X stepper motor current
alpha_max_rate 11000.0 # mm/min
beta_step_pin 2.1 # Pin for beta stepper step signal
beta_dir_pin 0.11 # Pin for beta stepper direction
beta_en_pin 0.10 # Pin for beta enable
beta_current 2 # Y stepper motor current
beta_max_rate 11000.0 # mm/min
gamma_step_pin 2.2 # Pin for gamma stepper step signal
gamma_dir_pin 0.20 # Pin for gamma stepper direction
gamma_en_pin 0.19 # Pin for gamma enable
gamma_current 0.5 # Z stepper motor current
gamma_max_rate 500.0 # mm/min
System configuration
Serial communications configuration ( baud rate defaults to 9600 if undefined )
uart0.baud_rate 115200 # Baud rate for the default hardware serial port
second_usb_serial_enable false # This enables a second usb serial port (to have both pronterface
# and a terminal connected)
#leds_disable true # disable using leds after config loaded
#play_led_disable true # disable the play led
Kill button (used to be called pause) maybe assigned to a different pin, set to the onboard pin by default
kill_button_enable true # set to true to enable a kill button
kill_button_pin 2.12 # kill button pin. default is same as pause button 2.12 (2.11 is another good choice)
Only needed on a smoothieboard
currentcontrol_module_enable true #
Switch module for spindle control
#switch.spindle.enable false #
alpha_max_travel 500 # max travel in mm for alpha/X axis when homing
beta_max_travel 1000 # max travel in mm for beta/Y axis when homing
gamma_max_travel 100 # max travel in mm for gamma/Z axis when homing
Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
alpha_min_endstop 1.24^! # add a ! to invert if endstop is NO connected to ground
alpha_max_endstop 1.25^! # NOTE set to nc if this is not installed
alpha_homing_direction home_to_min # or set to home_to_max and set alpha_max
alpha_min 0 # this gets loaded after homing when home_to_min is set
alpha_max 250 # this gets loaded after homing when home_to_max is set
beta_min_endstop 1.26^! #
beta_max_endstop 1.27^! #
beta_homing_direction home_to_min #
beta_min 0 #
beta_max 250 #
#gamma_min_endstop 1.28^! #
#gamma_max_endstop 1.29^ #
#gamma_homing_direction home_to_min #
#gamma_min 0 #
#gamma_max 120 #
optional order in which axis will home, default is they all home at the same time,
if this is set it will force each axis to home one at a time in the specified order
#homing_order XYZ # x axis followed by y then z last
homing_order XY # x axis followed by y then z last
optional enable limit switches, actions will stop if any enabled limit switch is triggered
alpha_limit_enable true # set to true to enable X min and max limit switches
beta_limit_enable true # set to true to enable Y min and max limit switches
gamma_limit_enable false # set to true to enable Z min and max limit switches
alpha_fast_homing_rate_mm_s 50 # feedrates in mm/second
beta_fast_homing_rate_mm_s 50 # "
gamma_fast_homing_rate_mm_s 4 # "
alpha_slow_homing_rate_mm_s 25 # "
beta_slow_homing_rate_mm_s 25 # "
gamma_slow_homing_rate_mm_s 2 # "
alpha_homing_retract_mm 5 # distance in mm
beta_homing_retract_mm 5 # "
gamma_homing_retract_mm 1 # "
#endstop_debounce_count 100 # uncomment if you get noise on your endstops, default is 100
## Network settings
network.enable true # enable the ethernet network services
network.webserver.enable true # enable the webserver
network.telnet.enable true # enable the telnet server
network.ip_address 192.168.99.14 # the IP address
network.ip_mask 255.255.255.0 # the ip mask
network.ip_gateway 192.168.99.1 # the gateway address
