LR4 YZ Plate Attachments
I see the YZ side plates have these little triangles of holes on each ‘shoulder’. I’d like to use these to attach a drag chain. Is there any pre-existing model for something which sits on this shoulder and attaches to the three holes? I am looking for a starting point to model and print my own attachment.
Maybe Lowrider 4 CNC Y axis drag chain mount by Alan Lowery | Download free STL model | Printables.com will work for you?
If not, check out: Negative for LowRider 4 YZ plate accessory holes. by V1 Engineering | Download free STL model | Printables.com
If you have the modeling skills, this blank will give you all the dimensions you need to create what you want.
That drag chain won’t fit in my setup, but the negative is exactly what I wanted. Thank you!!
