LR4 Strut plate vs X-rail length, imperial to metric round off error
Actually…
If your rails are longer, the braces will not be able to attach to the plates without the rails pushing them out.
It’s a common alignment issue.
The LR4 docs say
The adjustment would be to check your end braces to rail connection and to verify your lower X rail is not actually touching the XZ plate. If it is trim or file your rail a bit shorter.”
