I looked through quite a few topics to avoid duplicating a topic that was already discussed, but I haven’t found one similar.
The question is how to prioritize pipe options when there is more than one available. I’ll have to use stainless pipes. They are sold by weight, so lower weight means lower cost. The material quality options are 304, 304L, and 316. The dimensions I am aware of are 30x1.5mm (1.07Kg/m), 30x2mm (1.4Kg/m), 30x3mm (2.03Kg/m), 32x1.5mm (1.15Kg/m). Only 30x1.5mm and 30x2mm are available as SS316. 304 should be much cheaper than 316. 304 is about 6EUR/Kg. For 316 I still do not have any price.
The question is how to prioritize available options. Should I go for the biggest diameter with 32x1.5; or go with the heaviest to keep the x axis pressed down with 30x3mm; or with the lightest with a thickness above 1.5mm, which is 30x1.5mm?
If heavier/thicker gives a benefit, I would go with it, but if there is no added benefit, I would go with the cheapest/lightest that complies with design guidelines with a thickness of above 1.3mm. Essentially, 30x1.5 and 32x1.5 will be similarly priced, 30x3 will be almost double in price, and 30x2mm will be somewhere in between.
