LR4 speed and accelleration default and limits
Hello,
What are the default (provided in the default config file) and the practical speed and acceleration limits?
I reported a but in one of the software I use in relation to the estimation job time. The actual time us much longer than the estimated. The dev says that everything in the software is ok and blames a limit on speed acceleration in the machine that is different that what I provided in the software. I am not really convinced because the job runs at 1.5 mm/min the acceleration is set to 1000 mm/s2. Since job is a laser engraving on a small surface I doubt the acceleration has an impact as to ore than double the overall time (estimated 20 min actual more than 40 min).
Thanks
It depends on the control board you are using.
If you are using any of the jackpots you can see these details in the settings tab.
Yes Jackpot 3. I will look at it lather than. Does it also shows the max possible value?
Yes it does, for each axis. XY are set the same, Z is lower.
