Looking to build my first CNC and looking for some advice about the parts and where others have sourced them. I recently made multi-layered print, 60" x 30" ,using foam and cardstock and found the cutting part taking too much time and not being as clean as I would like it. I fell down a rabbit hole and have decided to build the LR4 (8’ x 4’) and use a drag knife to do my cutting. I have some parts from a previous project and some scrap metal from work and was wondering if I could use it for the LR4, any advice would be appreciated.
Mostly just using it to cut cardstock and foamboards though I would like to use it for woodworking and the other fun CNC stuff. Ive read that using lasers is possible for foam but I’ll have to explore further. Trying to keep cost down.
Rails: Got some 10ft steel tubes but they only have a 25.4 mm OD (1") and is 3 mm thick. From other threads it seems like I should use a proper 1" emt conduit. What about the rail for the Y rail, can I use this tubing and adjust?
XZ Plates: 0.2 mm thick steel kind of rough on both sides. Not sure how flat it needs to be. I have access to some basic hand tools and welding machine.
Control board: Any inexpensive options recommendations? Jackpot, SKR, Makerbase MKS DLC32? Not sure how tariffs would affect Jackpot cost
Stepper motor: Nema 17 0.42N.m 1.7a 2 phase 24 mm shaft. Is the holding torque sufficient?
If anyone has recently purchased parts for the LR4, any suggestions to where to source the belt, linear rails, and other specialty parts?
