Some background: I’m currently troubleshooting my recent LR3 build as I start printing a LR4 out of PCCF. My LR3 is skipping steps (seems like on X mainly) randomly after cutting for > 1 hour (<0C temperature ambient) then Y will go out/derail as I then start cutting full depth. Y may be randomly skipping as well. This doesn’t seem like a torque/grub slipping issue but just the motors giving up for a few cm of steps intermittently.
Now I probably just need to just tune this, I don’t think my speeds are too aggressive. Slotting 7mm DOC, 1/8th bit, 10mm/s in Pine plywood isn’t that much load right? I’m using chip loads and RPM from a calculator. But as I rechecked all my wiring I got the 5V mixed up on the end stop wiring messed up on my SKR board and burnt it up
My next attempt is going to be with fresh set of drivers and a new control board, plus adding some 40mm fans to the enclosure, so that may sort it out.
As I wait for the replacement board and to try and tune things it got me thinking. The X axis has 1/2 the torque as Y due to the single vs. dual steppers right? Ignoring rigidity concerns on Y and derailing with too much torque on the X axis for now, 3/4" oak plywood isn’t cheap these days.
StepperOnline has a longer closed-loop stepper https://www.omc-stepperonline.com/nema-17-closed-loop-stepper-motor-80ncm-113-29oz-in-with-encoder-1000ppr-4000cpr-17hs24-2004d-e1k and driver board that seems like it might work with the Jackpot passthrough stepper controls
Their stepper driver appears compatible with 5V signals:
The biggest challenge here is the 80mm motor length for the added torque and rotary encoder.
Looking over the LR4 parts, it seems X stepper length is possibly unnecessarily constrained by the part layout? This seems easy enough to just cut out and possibly the biggest benefit?
Y seems a little trickier, the Z endstop mounting would need to be modified significantly and possibly rotating the stop. But it seems like this should be feasible to accommodate an 80mm motor, there’s not a lot of clearance issues intruding inboard in this area to add bracing?
Z seems less interesting to make closed loop or make stronger. Z rapids don’t seem AS interesting (I’m wanting to do some 3D carving eventually, but even then X/Y clearing should take most of the time), and much more challenging to adapt the design for. And assuming Z doesn’t collapse under the weight of the tool I would assume there’s not much load induced by the motion.
BOM cost seems reasonable, <200 for 3 motors and drivers + cables possibly and if the fault signal works to indicate repeated lost steps (Seems a little unclear) then that can halt a job with minimal material damage which is even better. I recall reading the Jackpot has a fault input although understanding how the output triggers from the drivers may be challenging.
I’ve seen a thread on using a closed loop stepper for fast Z on the MPCNC, but not much else. Has anyone else tried this?
