LR4 Jackpot error new setup
Good morning, everyone,
I have just completed the assembly as announced on my
https://forum.v1e.com/t/lowrider-v4-from-italy/48893/22?u=dfm_maker
Connected everything.
I start with the procedure of installing fluidnc and then inserting the configuration files from github.
The endpoints all work correctly.
Engines are seen all 5 .
I attempt homing, but I get this message:
“ Homing fail. Pull off travel failed to clear limit switch. Try increasing pull-off setting or check wiring.”
now i would like to ask:
is the recommended version of fluidNC still 3.9.1?
WebUI 2 or 3?
Should the configuration files be put on the Flash or SDCard?
Sorry for the maybe trivial questions, but I wanted to be precise in the configuration once and for all.
Other geeky thing, can I use fluidterm for debugging with the usb cable with the 24 power on?
Thank you for any help you can give me.
Beppe.
Which end stop is failing to clear?
ok Start witch firmware 3.9.3 and WebUI 3
Enter in debug mode ($Message/Level=Debug)
$ss
[MSG:INFO: FluidNC v3.9.3 GitHub - bdring/FluidNC: The next generation of motion control firmware]
[MSG:DBG: Running after-parse tasks]
[MSG:DBG: Checking configuration]
[MSG:INFO: Machine LowRider]
[MSG:INFO: Axis count 3]
[MSG:INFO: Axis X (3.000,1223.000)]
[MSG:INFO: Motor0]
[MSG:DBG: TMCStepper Library Ver. 0x703]
[MSG:INFO: Axis Y (3.000,2443.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Motor0]
[MSG:INFO: Z Pos Limit gpio.32]
[MSG:INFO: Motor1]
[MSG:INFO: Z2 Pos Limit gpio.34]
[MSG:DBG: X Axis StealthChop]
[MSG:DBG: Y Axis StealthChop]
[MSG:DBG: Y2 Axis StealthChop]
[MSG:DBG: Z Axis StealthChop]
[MSG:DBG: Z2 Axis StealthChop]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: Probe gpio.36:low]
ok
now try endstop manual test:
[MSG:DBG: Y Neg Limit 1]
[MSG:DBG: Limit switch tripped for Y motor 0]
[MSG:DBG: Y Neg Limit 0]
[MSG:DBG: Y2 Neg Limit 1]
[MSG:DBG: Limit switch tripped for Y motor 1]
[MSG:DBG: Y2 Neg Limit 0]
[MSG:DBG: X Neg Limit 1]
[MSG:DBG: Limit switch tripped for X motor 0]
[MSG:DBG: X Neg Limit 0]
[MSG:DBG: Z2 Pos Limit 1]
[MSG:DBG: Limit switch tripped for Z motor 1]
[MSG:DBG: Z2 Pos Limit 0]
[MSG:DBG: Z Pos Limit 1]
[MSG:DBG: Limit switch tripped for Z motor 0]
[MSG:DBG: Z Pos Limit 0]
now try Homing X
ok
$HX
[MSG:DBG: Homing Cycle X]
[MSG:DBG: Homing nextPhase FastApproach]
[MSG:DBG: Starting from 0.000,0.000,0.000]
[MSG:DBG: Planned move to -1342.000,0.000,0.000 @ 1500.000]
[MSG:DBG: CycleStop FastApproach]
<Home|MPos:-1342.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
[MSG:INFO: ALARM: Homing Fail Approach]
ALARM:9
ok
No move motor.
This for all axies
config.yaml default from github
So it looks like the problem is with your X endstop. You say $limits shows it works correctly, though?
This is assuming config.yaml is ok…
Can you check if you can manually move the motors using the commands on the command terminal? The idea is eliminate potential problems.
  1. check esp32 controller to see if all motors don’t move. possibly issue is one the jackpot
  2. if only x motion is not working than switch x and y stepper connection and see if it works on a different driver output. if x stepper moves after switch probably x driver bad. if you still have no motion on just the x stepper even after switching drivers than likely the motor or wiring is the issue.
1.Power off controller
2. move x carriage away from x home switch
3. Power On controller
5. connect to FluidNC gui
6. in the command console type
G91
G1 X-5 F500
G1 X5 F500
G90
This moves the x just 5 steps and should respond with ‘ok’ if successful on each entry. change the x to y or z depending the the axis your checking.
Hi Ernest,
Sorry I didn’t reply to you but I just got back from 2 weeks away abroad.
I will do the test these days and update you.
Thanks again
