LR4 build in Germany from a total CNC newby
Hello,
my name is Philipp and I’m located in bavaria, 37 years old and I have zero experience with cnc. Came across the LR 4 in the woodworker forum and @Tokoloshe who presented his build there. I have some experience in 3d printing with my Ender V2 and in general woodworking as hobby.
I just ordered the hardware kit, jackpot controller and XY plates over the v1 shop. I’m still not sure which size my LR4 will have but i think 1250mm x 1800mm roughly.
I upgraded my printer to the flashforge adventurer 5 pro and will start printing the parts soon. Are there any further suggestions about the prints? At printables.com I did’nt find much information.
@twh344 shared information about printed parts in his thread, but printed in petg, I want to print most parts in PLA.
That’s it for the moment. Thanks to the community for this awesome project and the help I’ll need in the future :wink:
Philipp
This should get you started, LowRider CNC V4 - V1 Engineering Documentation
reduce your first layer speed to about half. some people are having first layer adhesion issues ( its totally random) other than that, if you did the klipper mod make the calilantern tests. happy printing and the best of the luck with your lr4
Hey Philipp (another one!!), nice of you to see you here. 37 is a good age to start with a CNC, so did I. :slight_smile: As Ryan mentioned: the docs have all the information you need regarding the infill etc. PLA is also the recommended material.
Richtig cool, dass du hier bist. :slight_smile:
Thank you guys. I’ve read the documentation but in another thread I’ve read that somewhere a 0.6 nozzle is recommended for some parts and stuff like that. That’s why I thought there are more advices out there.
But I will use the info that I’ve found so far.
No, any nozzle is fine. Sometimes I list me exact settings but nothing is that sort of critical. Anything important is listed. Any nozzle, recommended infill at least, 2-3 walls is good.
Hi Phil,
If only we had known each other before, then we could have shared the shipping. I am also totally new in the CNC area.
I come from near Hanover and want to start this year with the LR4.
I’m looking forward to your experiences :smiling_face:
Heh, I am from Oldenburg. :yum:
Good to know :grin:
I didn’t start the CNC road trip unit I was 57 with MPCNC Primo. I just about finished my 2 month LR4 project (I probably could have done in in hours, not months) LOL HOWEVER, the best advice I can give having just gone through the build myself is READ THE DOCS then read them again challenging yourself to identify that which you missed during the first reading. Simple things that cause issues are the ones we tend to overlook. Best thing is everyone here is willing to give a hand when needed (couldn’t have done this without all their input and help.)
Follow the yellow brick road… then worry about customization. :slight_smile:
The print is making (slow) process. Looking good so far.
Hey guys,
My braces are not printed as good as I’ve expected. Printed in pla at 200 degrees.
Which printer do you use?
Flashforge adventurer 5m pro
Unless I am just not seeing what you are, those look fine to me. They will be covered in dust soon hopefully and you wont ever see that :rofl:
just don’t know how the tolerances are for the parts and I recognized that the holes are not as good and the overhang of the screw holes seems not right.
For a lot of parts I have seen used and abused around here just fine, yours look pretty damn good to me. I wouldn’t worry about that little bit at all.
I agree with Jonathan. They look fine. :slight_smile:
I can only agree, that looks good.
I bought my parts mostly from Amazon Germany but I can only advise you to go for quality parts in this areas;
The 14 roller bearings (buy SKF or similar)
Buy quality liniar rail
Get some good Dupont connectors not Temu stuff.
End stop switches with a stiff leaver instead of the spring with roller is more precise.
ESP32 buy a genuine one.
Usb cable find quality one some of them is not for data transfer.
It is now worth using the cheapest parts or you will take your machine apart again.
My bearings failed after two months.
Good luck
