Hi all - I recently ran a project I was excited about, only to find out that my y-axis travel wasn’t what I expected (it was short). My plan is:
* Check/tighten grub screws
* tighten y-belt tensions
Two questions:
How does one axis the grub screws on an assembled LR3? How much disassembly do I need to do (I didn’t assemble this part).
How tight is tight on the belt. I see reference to a bass drum. It’s tight, but I can certainly pull some slack into it.
Many thanks. Despite all this love this machine, and looking forward to building a torsion table next to a) flatten my work area b) reduce the overbuilt footprint of my current frame.
How short was the travel, and was it short by the same proportion over the whole move or did it lose position partway through the job? A consistent percentage error usually points to the steps per mm setting, while a growing or random offset is more typical of a slipping pulley or skipped steps. Knowing which one it is would tell you whether the grub screws and belts are the place to start.
It was a by the same proportion. I cut two 45" circles from a sheet of plywood. Both were 45" in the x axis, but 44" in the y-axis. So I didn’t think it was a grub screw issue? Maybe I could tighten the belts? More than happy to methodically chip away, but I looked at the gantry and had no clue how to get to the grub screw so I got derailed at step one
I had had significant issues at the start of the cut getting the y-axis to home correctly, and modified some things to get it to tap, bounce, settle evenly. But when the cuts came, they were a bit short.
I was thinking steps per mm settings, but the trouble shooting here seem to indicate to chase that second, after tightening grub screws?
Any recommendations on how to tweak the steps per mm?
An inch out over 45" is pretty far out. Can we get more details of your LowRider build? What version of LowRider? Which controller? Where did you source belts and pulleys from?
44 out of 45 is about a 2.2% shortfall. If it is a steps/mm error, the value would need to go up by roughly that much. But before changing anything, what controller and firmware are you running, and has steps/mm ever been calibrated on this build? MakerJim’s questions matter here too. A wrong pulley tooth count would give you the same kind of proportional error.
