I noticed today after homing my machine, the front bearing wheel and rail aren’t touching. They are ~2mm off the table. Maybe I need to square the machine again?
That got me thinking, I am probably ~50 cutting hours into the machine. What maintenance do I need to do?
When I built the LR3, everywhere I had a metal screw going into metal (not nylon nuts) I used blue loctite. I did randomly check some screws and some are loose. So that is probably a start.
What else should I consider checking / doing?
