I’m sure this has been asked before but I absolutely cannot find the solution to my problem… when I put my design into the machine and begin milling, it mirrors my design every time. I cannot figure out the issue. I have checked all the hardware and plugs countless times and everything is assembled to V1’s instructions. I am a novice to CAM software and thought that was the problem but everything appears to be correct with the files… what am I missing here? Has anyone else had this issue?
Please Help!
Please explain in layman terms…
Thank you!
Whichever axis is flipped you need to power down and turn over the stepper plug. Setup - V1 Engineering Documentation
Check your coordinate system.
When facing the machine, X+ should move to your right. Y+ should move away from you and Z+ should lift from the table.
The LR is designed so that the single motor along the gantry is X, so you should be facing the machine with the gantry spannimg the table in front of you.
Thanks! This seems to have solved it… I was sure I had tried this already. Guess not.
I finally got it worked out, thanks!
