Well i finally got my LR 3 together today. I decided to go with a 3’x6’ work area so i didnt have to modify my current work bench. If things take off where i need a bigger work area then i will figure that out when that time comes. I have the skr pro, TFT35 and ESP01 (havent messed with it yet) and have it set up for touch screen. The skr pro has 4 ports for power…i have the power and motor power ports jumped together and im assuming the other 2 are specifically for 3d printers. I plugged it in and tested everything and noticed i had to reverse the z2 motor since it was working against the z1. Other than that im excited to get it going. I found some 1/4" mdf to cut the strut plates.
Is it possible to run the LR3 from an ipad? I have an OTG dongle for it to connect any external usb devices if thats needed or if i can use the ESP01.
