Does someone have this documentation LowRider CNC V3 - V1 Engineering Documentation in pdf version?
I would really appreciate it.
Print to PDF is your friend. Can’t upload it because it is too big.
Could you send me a link please?
https://docs.v1e.com/lowrider/
There is the link for the docs page. Open it and click print, then change your printer to save as PDF. Then you will end up with a PDF version of the docs
I found github link with documentation in markdown, so I used that. Is it link you meant?
You can save any page as a PDF…I spent a ton of time looking for a PDF plug in, turns out I didn’t need it. All browsers should have this built in.
Thanks for your answer. It seems like you are using Google Chrome. I am using Opera and Vivaldi and it does not seem like it is there as built in function. I have to look around more.
As Philipp says, you use the Print menu and change the destination printer to PDF file.
