OK I may have panicked . I have gone back to find out what you asked, and yes it does say printer not connected, but it is moving when I use the controls on the screen. So I guess it doesn;t matter too much.
anywhere I can get a test file to see it working. Before I go down the cnc software route. Can anyone recomend a good cnc slicer
I think I have made a file using kiri moto, which I found online, it has an .nc extension.
Anyway when I try to load the file it says the hotend temperature is belowe 180 and wont let me continue. But we dont have a hot end, is there a sensor I need to dissable somewhere.
Most of us use the test crown. That is a good test. About the only thing that it won’t really do is let you know if you’ve got things set up to produce a mirror image of what you want.
I use Estlcam as a CAM package, it’s fairly popular here. Kiri:moto should also work. There are also post-processors for Fusion360 and FreeCAD that are supposed to work if you use those for design. (I use FreeCAD, but do not use it to produce gcode files.)
You can rename nc files as gcode. Same with gco files.
All going good now, I am at the software stage now. I have been recomended Aspire, which I think it pretty good sofware, my question is, what post processor do I use, it can work with loads of different ones, is there a particular unit that the lowrider is based on, or is it just generic, there is a couple of generic options like grlb gcode or gcode.tap but the software has a lot of cnc machines listed.
You want a Marlin post processor. According to this post, versions 8.5 of Aspire ships with a Marlin postprocessor, implying earlier versions did not. Due to its cost, there are few Aspire users on this forum.
I have both Aspire and Vcarve Desktop. Here is a PP file that most of us Vectric users use:
Marlin_mm-test5.zip (1.2 KB)
excelent, thank you.
