Greetings all,
I have been following and reading a lot in last few months.
Finaly desided to order bundle with printed parts, as 3D printing is all new for me.
I am a carpenter by trade and I was looking how to aquire CNC for some of my projects.
I am no good for codes, lines, Marlin and that stuff ;(, so I will need advices and help…(thank you)
Here is what I ordered for now
Lowrider2 bundle
6 endstops
3D printed parts - 25mm
SKR 1.4 turbo
TMC2209 steper drivers x5
BTT TFT35 e3 v3
Question
Is power suply that comes in bundle (12v 6A) suitable for SKR 1.4t and steper motors?
I own multiple hend routers and will use few depending on work I want to do. Mostly cutting plywood or hardwood.
You’re gonna have to get your hands dirty and learn some stuff for the skr turbo. Buying a board from Ryan would save you some trouble. I don’t mean to try to drag you down, I just want to set your expectations. That board will need some work to get running for a CNC.
Here is update,
It took forever for parts to come (Croatian post issues)
but when it came I did not sleep until all was put together
I used Rob H firmware setup and after some tweaking it all flashed and worked, sort off…
Thank you Rob
I get message “busy processing” after I leave everything powered for few minutes.
Like it goes to sleep mode and cant wake up
Over the weekend I am putting table together
Edit
Busy processing comes out when i give him a comand he can not do, like home and there is no endstops… hmm
Need to put all together asap
Progress…
Got stucked on end stops…
I am sure i need to change something just dont know what.
X axis takes long to home
Y axis goes in wrong direction- need to revers it.
Z axis not homing…
Thanks,
I had to put whole this aside for a week, busted flex couplers, and got really confused… need few days to went
I used firmware from Rob H, from this forum, he has same setup and for him it all works great.
I never found any pic of the mainboard to see wiring,…
All was moving correct and in good directions.
Problems that i found later is that
left end switch works and right dont,
when pressing home on Z axis it goes up (should go down)
Not detecting Z end switches
Tried drawing some letters and it got them mirrored on Z axis
Busy week in front of me, I hope I get couplers delivered and some wiring so I can redo end swithces again.
Until then I will ask Rob H to send some pics of his board to compare
