Been seeing more and more about a Lowrider Waterjet.
Thought I’d shed some light on waterjets in general and give a few things to consider. Love to hear your thoughts and input on the subject.
Costs… Waterjet Specific - Pump and/ or pumps, Intensifier, Filters, Chiller, Garnet, Hopper (tank for storage of garnet), Mixing chamber (area where water and garnet combine) Actuators for water and garnet (to hold pressure during traversing and timing for garnet and water mixtures. Garnet to soon, clog, too late deformation of material surface, too little garnet poor edge/cut quality, too much equals wasted garnet into the tank), Diamond Orifice (Ruby is an option but only at lower pressures), Mixing tube (this is the cutting tip), cutting area tank, supports for the cutting slats (.250 or thicker to support the weight of the materials going to be cut), cutting slats (.125 or thicker to reduce vibration and splash back during cutting and to reduce the time of replacing them).
Then we have all off the cnc stuff, steppers, lead screws. (Yup, probablt not going to be able to use belts, the pressure from the cutting head requires that everything can’t move at all or it decreases tolerances.)
Probably going to have to increase the rigidity of the tubing. If the head lifts from the blow back of the water stream it will change your cutting area and tolerances.
And most of all, the elephant in the room is conquering the kerf. Corner, edge/taper controls. Without being able to tilt the head you will never have a square, concentric part. (I.e. a .250 6061 12" diameter would be 12" on top and 12.025 on bottom) You can slow down the cut speed to cut/erode more material on top, but now your top is undersized and the bottom is oversized. This becomes really prevalent with thicker materials.
Now on to maintenance.
All of your seals can’t leak anywhere or you lose pressure and create heat. Heat creates catastrophic failures. Also any pressure drops changes your cutting tolerances. If there is a issue with the pump, any of those particles materials get passed on down stream and cause problems with everything else in its path)
Let’s move on to the tank… you have all that stuff you have been cutting is in the tank and you have to remove it. Now you have to drain the tank and remove all those materials and garnet. Depending upon the tank size and materials, can be quite labor intensive. Also, if you have been cutting things that are possibly hazardous materials, you will have to have proper authorities dispose of it.
Safety!!!
Most of all is Safety. I can not stress this enough, there is nothing worth your hand or arm or Your Life! No part is ever worth it!
So what happens in the event that you get cut. If you cut the tip of your finger, there is a good chance that you will lose that finger up to the closest knuckle. Cut your palm, good chance that you might lose function to most of that hand.
So when something gets cut with water, it turns your skin into a high speed water balloon. However, your skin only has so much elasticity. So it becomes a high speed water grenade. So you now have a cut and an explosion in the same area.
If you are cutting with garnet and not water only, now you have a whole other battle. You have just injected negative gram bacteria into your blood stream. So in addition to the water grenade you just absorbed, you now are fighting your heart in a battle against spreading bacteria throughout your body.
I’m sure that I’ve missed a quite few things, but look forward to hearing your thoughts on the subject.
#Waterjet
#21Questions
#FatKidsLoveCake
#AnyoneActuallyReadAllOfTheHashtags
#ProbablyNot
#Lowrider
