Lowrider V4, Y- Endstops
Hi All,
Just finished my Lowrider v4 build.
Set everything up, X and z homing work just fine.
I have the Y- Endstops mounted on the back side of the machine (back wheel parts), not on the side.
When I want to home Y, the machine travels back ( where the Endstops are located) But there is no adjustment screw on the belt mounts.
The Stock setup is for the side mounted endstops.
@Ryan is there a different version of the Y-Belt mount for that? or should I change it to the side mounted endstops?
Thank you very much.
I enjoyed the build so far very much. Looking forward to my first cuts.
That needs a couple firmware edits to make that work. I highly suggest to follow the location in the directions. That is an advanced use case and going to require CAM edits as well.
Thank you very much Ryan, then I’ll modify it to the stock configuration. No experiments here.
