LowRider V4: Wire length / controller position for 1300mm X
Hey all, I’m building a LR4 with 1300x2600mm cutting area and I’m worried about wire length. I received 3 extension cables in the kit, which should cover the steppers of YZ_Max and Core, but it seems the endstop wires might end up short, especially if I place the control board close to YZ_Min as suggested (which I want to do for convenience of access). Should I source additional extensions or will I be fine?
You can place it wherever you want. Closer to y0 is the common place. You can skip one brace and make it workt with that size. (Y axis wont matter) Only the x azis) hope you added another brace in your build for that size.
as per the strut plate the generator spat out, I’ll be using 8 braces total.
