Hi, getting there with my LR3 build. I have a successful crown test but am flailing around trying to do my first cuts, making the struts.
I have adjusted Ryans sketch in fusion, loaded it into estlcam and set up the toolpaths.
Loaded the resulting files into Repetier Host and ran it on my skr pro v1.2, things start happening, I get initial Z axis adjustments, then nothing.
I tried loading the gcode onto an SD card and the same thing happens.
I have tried just manually going line by line on the gcode and this seems to work fine so i’m at a bit of a loss what is going on. I have checked the settings in both programs and everything seems set up ok.
here is the start of the gcode, hopefully thats of some use
;Project Strut Plate- Custom v1_dwf
;Created by Estlcam version 11 build 11.245
;Machining time about 01:11:20 hours
G90
G00 X0.0000 Y0.0000 Z0.0000 F2100
G00 Z2.0000 F480
;No. 1: Part 39
G00 X64.2220 Y29.0626 F2100
G00 Z0.5000 F480
G01 Z0.0000 F3.000 S24000
G01 Z-1.0000 F3.000
G03 X69.8971 Y25.3250 I69.9818 J31.6308 F15.000
Please let me know if any further info would be of use in getting to the bottom of this issue.
thanks
