Lowrider V2 Upgrade to fluidNC - Errors in Config.yaml
Hi everyone,
i try to upgrade my LowriderCNC V2 to fluidNC, but unfortunately, i have problems with the config.yaml file so that my PiBot FluidNC Controller V96 Pro cannot detect my TMC 2209 stepper drivers.
Thank you in advance for any help!
these are the errors i keep getting, i will also insert my config file below.
[MSG:INFO: FluidNC v3.8.3 GitHub - bdring/FluidNC: The next generation of motion control firmware]
[MSG:INFO: Local filesystem type is spiffs]
[MSG:INFO: Configuration file:Tom_config_V1.yaml]
[MSG:ERR: Configuration error at /machine: Duplicate section uart1]
[MSG:ERR: Skipping key txd_pin indent 2 this indent 0]
[MSG:ERR: Skipping key rxd_pin indent 2 this indent 0]
[MSG:ERR: Skipping key rts_pin indent 2 this indent 0]
[MSG:ERR: Skipping key baud indent 2 this indent 0]
[MSG:ERR: Skipping key mode indent 2 this indent 0]
[MSG:INFO: Machine TomCNC_V1]
[MSG:INFO: Board PiBotV49P]
[MSG:INFO: SD Card cs_pin:gpio.5 detect:NO_PIN freq:8000000]
[MSG:INFO: I2C SDA: gpio.27, SCL: gpio.25, Freq: 100000, Bus #: 0]
[MSG:INFO: Stepping:I2S_stream Pulse:4us Dsbl Delay:0us Dir Delay:1us Idle Delay:254ms]
[MSG:INFO: Axis count 3]
[MSG:INFO: Axis X (3.000,1223.000)]
[MSG:INFO: Motor0]
[MSG:INFO: tmc_2209 UART1 Addr:0 CS:NO_PIN Step:I2SO.2 Dir:I2SO.1 Disable:I2SO.0:low R:0.110]
[MSG:INFO: X Neg Limit gpio.33]
[MSG:INFO: Axis Y (3.000,2443.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Y Neg Limit gpio.32]
[MSG:INFO: Motor1]
[MSG:INFO: Y2 Neg Limit gpio.34]
[MSG:INFO: Motor0]
[MSG:INFO: Z Pos Limit gpio.35]
[MSG:INFO: Motor1]
[MSG:INFO: Z2 Pos Limit gpio.39]
[MSG:ERR: X Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:ERR: Y Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:ERR: Y2 Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:ERR: Z Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:ERR: Z2 Axis TMC driver not detected - expected 0x21 got 0x0]
[MSG:INFO: Connecting to STA SSID:ASUS_8A_2.4GHZ]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connecting…]
[MSG:INFO: Connected - IP is 192.168.50.80]
[MSG:INFO: WiFi on]
[MSG:INFO: Start mDNS with hostname:http://fluidnc.local/]
[MSG:INFO: OLED I2C address: 0x3c width: 128 height: 64]
ok
<Alarm|MPos:0.000,0.000,0.000|FS:0,0|Pn:XYZ|Ov:100,100,100|A:>
Config.yaml:
board: PiBotV49P
stepping:
engine: I2S_STREAM
idle_ms: 254
pulse_us: 4
dir_delay_us: 1
disable_delay_us: 0
uart1:
txd_pin: gpio.0
rxd_pin: gpio.4
rts_pin: NO_PIN
baud: 115200
mode: 8N1
axes:
shared_stepper_disable_pin: NO_PIN
x:
steps_per_mm: 50.000
max_rate_mm_per_min: 9000.000
acceleration_mm_per_sec2: 200.000
max_travel_mm: 1220
soft_limits: false
homing:
cycle: 2
positive_direction: false
mpos_mm: 3
feed_mm_per_min: 300.000
seek_mm_per_min: 1500.000
settle_ms: 500
seek_scaler: 1.100
feed_scaler: 1.100
motor0:
  limit_neg_pin: gpio.33:high
  limit_pos_pin: NO_PIN
  limit_all_pin: NO_PIN
  hard_limits: false
  pulloff_mm: 4.000
  tmc_2209:
    uart_num: 1
    addr: 0
    cs_pin: NO_PIN
    r_sense_ohms: 0.110
    run_amps: 0.800
    homing_amps: 0.800
    hold_amps: 0.500
    microsteps: 8
    stallguard: 0
    stallguard_debug: false
    toff_disable: 0
    toff_stealthchop: 5
    toff_coolstep: 3
    run_mode: StealthChop
    homing_mode: StealthChop
    use_enable: false
    direction_pin: I2SO.1
    step_pin: I2SO.2
    disable_pin: I2SO.0:low
standard_stepper MODEL can use for extend driver output
for example: plug on the capnut H4,
the output signal from the TB4-X IS “EN STP DIR GND” to driver
#####// for some extend driver need “:low” the en signal
####///direction_pin is used to control the direction. You can invert the direction by changing the active state attribute (:high or :low)
y:
max_travel_mm: 2440
soft_limits: false
homing:
cycle: 2
mpos_mm: 3
settle_ms: 500
seek_scaler: 1.100
feed_scaler: 1.100
#Y
motor0:
  limit_neg_pin: gpio.32:high
  hard_limits: false
  pulloff_mm: 4.000
  tmc_2209:
    uart_num: 1
    addr: 1
    cs_pin: NO_PIN
    r_sense_ohms: 0.110
    run_amps: 0.800
    homing_amps: 0.800
    hold_amps: 0.500
    microsteps: 8
    stallguard: 0
    toff_disable: 0
    toff_stealthchop: 5
    toff_coolstep: 3
    use_enable: false
    step_pin: I2SO.5
    direction_pin: I2SO.4
    disable_pin: I2SO.7
#A
motor1:
  limit_neg_pin: gpio.34:high
  hard_limits: false
  pulloff_mm: 4.000
  tmc_2209:
    uart_num: 1
    addr: 3
    cs_pin: i2so.14
    r_sense_ohms: 0.110
    run_amps: 0.800
    homing_amps: 0.800
    hold_amps: 0.500
    microsteps: 8
    stallguard: 0
    toff_disable: 0
    toff_stealthchop: 5
    toff_coolstep: 3
    use_enable: false
    step_pin: I2SO.13
    direction_pin: I2SO.12
    disable_pin: I2SO.15
stepstick MODEL can use for onboard driver output,
for example: A4988 MS1 MS2 can be set in the plugnut, and the ms3 can set in this yaml file such as “ms3_pin: I2SO.6:low”
notice: don’t plug the capnut when use this model
the output signal from the TB4-Y IS “2B 2A 1A 1B”
z:
steps_per_mm: 200.000
max_rate_mm_per_min: 900.000
max_travel_mm: 300.000
soft_limits: false
homing:
cycle: 1
positive_direction: true
mpos_mm: 3
seek_mm_per_min: 800.000
settle_ms: 500
seek_scaler: 1.100
feed_scaler: 1.100
motor0:
  limit_neg_pin: NO_PIN
  limit_pos_pin: gpio.35:high
  hard_limits: false
  pulloff_mm: 4.000
  tmc_2209:
    uart_num: 1
    addr: 2
    cs_pin: NO_PIN
    r_sense_ohms: 0.110
    run_amps: 0.800
    homing_amps: 0.800
    hold_amps: 0.500
    microsteps: 8
    stallguard: 0
    toff_disable: 0
    toff_stealthchop: 5
    toff_coolstep: 3
    use_enable: false
    step_pin: I2SO.10
    direction_pin: I2SO.9
    disable_pin: I2SO.8
 #B
motor1:
  limit_pos_pin: gpio.39:high
  hard_limits: false
  pulloff_mm: 4.000
  tmc_2209:
    uart_num: 1
    addr: 3
    cs_pin: i2so.19
    r_sense_ohms: 0.110
    run_amps: 0.800
    homing_amps: 0.800
    hold_amps: 0.500
    microsteps: 8
    stallguard: 0
    toff_disable: 0
    toff_stealthchop: 5
    toff_coolstep: 3
    use_enable: false
    step_pin: I2SO.18
    direction_pin: I2SO.17
    disable_pin: I2SO.16
probe:
pin: gpio.2:low:pu
toolsetter_pin: NO_PIN
check_mode_start: true
hard_stop: false
########//gpio.2 and gpio.26 need :pu when use for input
i2so:
bck_pin: gpio.22
data_pin: gpio.21
ws_pin: gpio.17
spi:
miso_pin: gpio.19
mosi_pin: gpio.23
sck_pin: gpio.18
sdcard:
card_detect_pin: NO_PIN
cs_pin: gpio.5
start:
must_home: false
Begin OLED
i2c0:
sda_pin: gpio.27
scl_pin: gpio.25
oled:
i2c_num: 0
i2c_address: 60
width: 128
height: 64
radio_delay_ms: 1000
Begin relay
relay:
direction_pin: NO_PIN
output_pin: gpio.26
enable_pin: NO_PIN
disable_with_s0: false
s0_with_disable: true
spinup_ms: 0
spindown_ms: 0
tool_num: 0
speed_map: 0=0.000% 0=100.000% 1=100.000%
off_on_alarm: false
Begin PWM
pwm:
pwm_hz: 5000
output_pin: NO_PIN
enable_pin: NO_PIN
spinup_ms: 0
spindown_ms: 0
tool_num: 1
speed_map: 0=0.000% 10000=100.000%
off_on_alarm: false
Begin Laser
Laser:
pwm_hz: 5000
output_pin: gpio.12
enable_pin: NO_PIN
tool_num: 2
speed_map: 0=0.000% 255=100.000%
off_on_alarm: true
Begin 10V
10V:
forward_pin: NO_PIN
reverse_pin: NO_PIN
pwm_hz: 5000
output_pin: gpio.13
enable_pin: NO_PIN
spinup_ms: 0
spindown_ms: 0
tool_num: 3
speed_map: 0=0.000% 1000=0.000% 24000=100.000%
off_on_alarm: false
Begin YL620 RS485
uart1:
txd_pin: gpio.15
rxd_pin: gpio.16
rts_pin: gpio.14
baud: 9600
mode: 8N1
YL620:
uart_num: 1
modbus_id: 1
tool_num: 4
speed_map: 0=0% 0=25% 6000=25% 24000=100%
off_on_alarm: false
Add your yaml file to a zip and attach it. It’s hard to read that way and it loses the spacing which the file is very sensitive to.
Also, we completely avoid FluidNC v3.8.x versions. That was a very unstable time for FluidNC.
I’m not sure what settings a Pibot controller needs since most of us here using FluidNC have a Jackpot controller.
thank you for the fast reply.
the Pibot controller was easier to get here in Europe, which is why i bought it.
but are they not all comparable except for the used pins?
you can find the pins here on the site: PiBot FluidNC GRBL Laser CNC Controller V4.96 Pro
Tom_config_V1.zip (2.0 KB)
The Jackpot can be bought from Elecrow as well, that’s pretty easy. :stuck_out_tongue:
It looks like you took a sample PiBot config and didn’t update it. The errors are saying what is wrong.
It is defined at line 10 and line 315.
I think this just might be because uart1 is defined twice.
Are you using a relay and a spindle or a laser?
I used the example config and added the motor driver info from a jackpot config i found. Then i edited the endstop pins. When it did not connect to my TMC 2209s, i tought i forgot to copy the uart lines so i copied it over.
i deleted the section again and now i only get errors because the board can’t find the motor drivers. here is the new log:
[MSG:INFO: UART1 Tx:gpio.15 Rx:gpio.16 RTS:gpio.14 Baud:9600]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: WiFi on]
[MSG:INFO: Relay Spindle Ena:NO_PIN Out:gpio.26 Dir:NO_PIN]
[MSG:ERR: PWM output pin not defined]
i don’t use a relay or laser.
Also, here is the new config.yaml. but now that i deleted the uart section at the top, how is uart defined?
Tom_config_V1_uartdeleted.zip (1.9 KB)
That’s almost certainly wrong for a PiBot versus a Jackpot.
Unfortunately , I don’t have a PiBot controller to test with nor any information about their design.
Most folks here are going to have that difficulty trying to help you.
Adding this- it’s not that I don’t want to help you; I’d love to get a LowRider owner up and running.
It’s that I just don’t have the details needed nor a reference system to help debug with.
hello,
yes i understand, no problem. That’s why i just ordered a jackpot 3, and because i can’t get the PiBot to update…
Thank you anyway!
