I have finished assembling my lowrider v3 but I am running into some issues trying to make my first cut. Of note, I cut out the strut plates by hand so this is the first time I am actually attempting to cut something with the router.
Before cutting anything I ran the crown test gcode and got what seems to be a pretty decent looking crown. Next I made a very simple model in fusion 360 to attempt my first cut with. The simulated toolpaths seemed to make sense, and I used flyfisher604’s post processor when generating the gcode.
When I go to run the gcode, the first thing I see on the screen is a dialog that pops up saying M0 Stop
with the option to press the Continue
button. When I press continue, the z axis starts moving upward and will keep moving up, smashing into the endstops and such until I hit the reset button. Its like it is trying to escape or something…
I took a look at the generated gcode but I am no expert as to what to look for. Trying to decipher some of the commands it all seems to make sense to a degree, however I noticed the first M0
stop command in the gcode includes a message Attach ZProbe
but I do not see this message on screen.
My first guess is that this M0 Stop I am seeing is actually the one letting you know to attach the ZProbe but for some reason I just don’t see the Zprobe message. To test this, I tried touching the two Zprobe ends together to see if the upward movement would stop, but it did not. I have otherwise confirmed with M119
that the Zprobe reads open when the two ends are separate, and triggered when they are touching.
Also I would expect this command to start moving the Z Axis downard instead of up. When using the move command, or homing the z axis it moves in the expected direction.
I have observed one other odd behavior that might be related. Sometimes when I initially turn on the machine if I move the z axis it will just keep moving until I press reset no matter which distance I have selected on the movement screen. Sometimes it even moves the wrong direction. But after I home the machine, it seems to work as expected and I cant always replicate this even when turning the machine on the first time.
I have attached the full gcode file here, but also included what I think is the relevant snippet below.
helloworld.gcode (56.1 KB)
;Fusion 360 CAM 2.0.16985
; Posts processor: MPCNC.cps
; Gcode generated: Tuesday, October 3, 2023 7:28:29 PM GMT
; Document: thingy v1
; Setup: Setup2
;When using Fusion 360 for Personal Use, the feedrate of
; Ranges Table:
; X: Min=8.938 Max=69.262 Size=60.325
; Y: Min=8.937 Max=69.262 Size=60.325
; Z: Min=-4.81 Max=15 Size=19.81
; Tools Table:
; T1 D=3.175 CR=0 - ZMIN=-4.81 - flat end mill
; Feedrate and Scaling Properties:
; Feed: Travel speed X/Y = 2500
; Feed: Travel Speed Z = 300
; Feed: Enforce Feedrate = true
; Feed: Scale Feedrate = false
; Feed: Max XY Cut Speed = 900
; Feed: Max Z Cut Speed = 180
; Feed: Max Toolpath Speed = 1000
; G1->G0 Mapping Properties:
; Map: First G1 -> G0 Rapid = false
; Map: G1s -> G0 Rapids = false
; Map: SafeZ Mode = Retract : default = 15
; Map: Allow Rapid Z = false
; *** START begin ***
; Set Absolute Positioning
; Units = mm
; Disable stepper timeout
; Set current position to 0,0,0
G90
G21
M84 S0
G92 X0 Y0 Z0
; COMMAND_TOOL_MEASURE
; Probe to Zero Z
; Ask User to Attach the Z Probe
; Do Probing
; Set Z to probe thickness: Z0.8
; Retract the tool to 40
; Ask User to Remove the Z Probe
M0 Attach ZProbe
G28 Z
G92 Z0.8
G0 Z40 F300
M400
M0 Detach ZProbe
