Lowrider Stanton Bench/MFT Table
When I built my Lowrider, I sacrificed my existing Paulk workbench for the space I needed**. While I’ve been enjoying the large format CNC, I definitely miss the huge workspace on the Paulk for assembly, clamping, etc. I built this modified Stanton Bench for my lowrider to reclaim some of this space when the CNC is not in use.
IMG_0435
Dave Stanton has a nice YouTube Channel and sells plans for his Stanton Bench online. It’s designed to turn any table into a functional workbench by sliding on with bench cookie supports. It’s setup for tracksaw work and makes a great crosscut station with a few benchdogs and 2 track clips that put the edge of the track flush with the edges of the table.
IMG_0432
It has 2 T-Track sections and 6 non-slip cushioning strips to hold things secure when working on them.
IMG_0434
The table slides on and off from the side
IMG_0441 (1)
One of the issues I had with trying to just use the Lowrider table as a work surface was that I was constantly contacting the belts. I feared over time that I would either accidentally damage it, or just prematurely stretch it. The nice thing about the Stanton bench is that it has a front ‘skirt’, and I modified the plans to have legs that stop around the belt instead of the bench cookies, protecting it from my fumbling:
IMG_0427
While I can leave it on when using the CNC for small jobs, for bigger jobs it slides off and has 2 french cleat hooks built into the legs for hanging on my french cleat wall. I’ll probably use it as a huge iPad stand for CNCjs:
IMG_0448
IMG_0444
** For anyone wondering, I did not trash my paulk bench, just turned it into a double-decker miter and router table with cheap 2x4 Basics work bench legs:
IMG_0003
Pretty slick.
Would you share how you got those storage bins attached to the French cleat?
I’m guessing he screwed a cleat to the back of the black-and-yellow bins. You can just see the corner of one in the background of the side-view of the table hanging on the french cleats.
Like Tom said, I screwed a cleat to them. It’s a nice feature of the french cleat wall that you can make a lot of accessories just by attaching leftover cleats to the back of something. I think I did do a backing board inside of the bins as well for exra support since the walls were thin. I don’t have a picture of the bins, but this one of a crate shows the concept:
ok, I’m sold.
How does one sub to a thread on mobile?
… Subbed. Does it work like that? Idk
