LowRider CNC- Full sheeter
I made the table a little more than 1/2" thinner than I wanted so I could use that Styrofoam house insulation as a spoil board…it’s awesome. $7/sheet and I offset it with 1/2" molding under the wheels. Pretty ideal I think.
It is kinda odd, it does not seem as rigid as the MPCNC but cuts better. Maybe the weight of the router helps damped vibrations.Not sure about that.
I have to say anything bigger than 2.5’ this is the way to go I think. I built the MPCNC as a cnc for small parts, 6"x6" tops. Turns out I kept making it bigger. This thing though, jeez I am a little impressed, I thought it might have to cut slower because of it’s size…nope it can handle much faster I think. Pretty sure that was at least 1/3 faster than I do with the mpcnc because of the depths I used and that was with a very old bit, the first downcut I bought, I thought for sure I would break it so I didn’t wan to lose a new one…cheap bastard. This was the first large cut and it was super dead on. Very easy to use. I will be cutting one of my MPCNC’s down for sure now.
