That’s awesome! The project keeps getting better with every update! I even managed to integrate your latest version into SolidCraft, hehe. I really like SolidCraft’s layout and interface, so I decided to experiment with this integration. It’s still a work in progress, but I’m pretty happy with the results so far. Great job, and keep up the amazing work!
Neat work! Consider WAGO connectors or at least turn the nuts upwards to avoid condensation/rusting, also, thoughts on using and/or cable lacing tutorial ![]()
No. ![]()
Just when I thought it was safe to go back into the water….![]()
Is that safe for work bondage? ![]()
Hey man, whatever you’re into. I won’t judge.
@Tokoloshe i wish we could get together! I think we would have a lot of laughs!!!
Love this! My 0,0 home is at the front right though is there a way to set that up?
It should handle it on the FluidNC side but I’ll need to add an option for the X limit switch on the other side.
Kyle’s warning about where feature creep can lead is fair, but the part about using AI is what stands out to me. Admitting you have ideas but haven’t written the code yourself takes some honesty, and drawing the line between what you could modify and what sits outside your skillset seems like a practical way to work. The curiosity to see where a silly idea lands is usually the reason these projects get finished at all.
That’s funny. I’ve been trying to figure out if you and a couple other new users within the past couple days are AI. I’m not certain but still leaning yes.
Pushed another update out. I think I might be done making major changes for now. Now just fixing smaller things. I think.
New
- Table power hub + dust port (Options, off by default): a panel under the table’s left end with the dust port, a power inlet, a switched ROUTER / VAC outlet and an always-on outlet. Add a shop vac + separator under the table. It is one way to build it, not an electrical design.
- Hoses and cords hang like ropes: the vacuum hose sags and rolls in its holders, and the router cord rides on it and drops off the beam’s end. The BOM lengths come from the drawn runs.
- All the wiring drawn (Show > Wiring): every motor and endstop wire through the YZ plates, the beam and the braces into the Jackpot box, down to the pins. X-ray parts makes the machine see-through, and you can trace a run end to end.
- Show replaces Layers: Parts and Areas as on / off buttons that combine freely.
- Automatic bit changes & probing: Start can now put the bit in, place and remove the touch plate, and resume by itself. In Real-world mode it also offers to run the job on the Ideal machine instead.
- Roundover bits, carved with their real profile.
- Torsion table has top and bottom skins.
Fixed
- A probe no longer goes through the touch plate and marks the stock under it.
- Resume right after a pause no longer gets lost.
- Real-world mode’s squareness test gave wrong answers on a warped spoilboard and in Lite detail.
- Homing switch clicks are no longer missed when the page is busy.
- With the table hub, the cords no longer hang in waves until the first move.
- Very large jobs (200k+ moves) no longer risk a stack error.
- If something on the page breaks, a bar now says so, with Reload and Report.
