LowRider 3 CNC mod: HIDE / PROTECT either of the Y AXIS BELTS inside metal strut / unistrut / superstrut) (v1.0)
Hey, that’s exactly the colors I used, for wood and for metal (blue and black on my plasma).
I just got a new video released showing full install, start to finish. I had hoped to have time to demonstrate it working, but the video was already over time, so that will have to be in another video.
Note: As of October 12, 2023 - the “Y1 Drive Mount NEW (print 1)” now prints without supports. Supports are still needed on the original (Y2) mount.
LowRider v3 DIY CNC mod: HIDE/PROTECT either of the Y axis belts INSIDE metal strut (unistrut/superstrut)!
Some pics of the new install:
Note:
Hi Doug, is there any plan to update the unistrut mod to work with the LR v4? I have the same issue with table orientation/shop layout, and need to load full sheets repetitively from the non-rail Y side. Removing the belt to load material isn’t the end of the world of course but I can see myself getting frustrated in the near future.
Cheers.
I have not yet done a hidden belts mod for the LR4. It is more challenging on the LR4 to “over engineer” a retroactive mod for this than it was on the LR3. Back during the beta testing phase I mocked something up but I did not ever install and test it. Being I use my large CNC table almost always as an assembly table and for things other than CNC, and frequently go back and forth, it is frustrating because I either have to continually remove and reinstall the belt, or else just don’t bother and then the belt is in the way. I may yet try. If I do succeed I will report back.
Hi Doug,
I decided to build your table with the unistruts anyway on the off chance you do release the mod for v4.
I was wondering if the suggested x beam length stays the same for v4 (ie. 56.1 - 56.5")
My table with Unistrut metal rail sides was built for LR3, but is now used with LR4, with essentially no modification to the table. I could have maintained the same cuttable X (which was over 49") but my LR3’s non-rail side rode very close to the edge of the Unistrut, so to fix that on my LR4, without messing with my existing table, I took my cuttable X down to about 48.5". I"m still able to flatten a spoil board that’s 49" wide because the flattening bit reaches further than the center of the bit, of course.
Below is a comparison of my cuttable area and several cuttable area values from the LR4 calculator, but the real key in the following table is the relationship between my X-rails and the width of my table (distance between the outsides of my Unistrut rails). Since my table width is right at 80mm wider than my X-rails, you can use that value to get a target table width for Unistrut rails, by adding 80 to your desired cuttable X.
Cuttable Area X-rails: Table width: Difference:
My table, cuttable of 48.5": 1398.0 mm (55.04") 1478 mm (58 3/16") +80 mm (3.15")
Calculator for cuttable of 48.0": 1384.3 mm (54.5") 1464.3 mm (57.65")* +80 mm (3.15")
Calculator for cuttable of 48.5": 1397.0 mm (55.0") 1477.0 mm (58.15")** +80 mm (3.15")
Calculator for cuttable of 49.0": 1409.7 mm (55.5") 1489.7 mm (58.65)*** +80 mm (3.15")
*57.65" is about 57 11/16".
**58.15" is about 58 3/16".
***58.65" is about 58 11/16".
Hopefully this info helps?
A key difference here between a normal stock build and mine is I remixed the Y rail clips to fit better onto the Unistrut metal rail, and to position the Y rail in the right place. I can share with you my remixed Y rail clips, as well as my “table extenders” and remixed belt tensioners.
Hi Doug,
Things have been coming along slowly but I have made some progress with your table design.
Are these the correct extenders to work with v4? Do the v4 tensioners bolt to the extenders or do I need to have new ones printed?
I couldn’t seem to find any tensioners or Y rail clips on your printables page.
Thanks a lot for sharing this design, really loving it so far.
Just curious, is anyone working on a similar mod for the LR4?
I made a different set for LR4. I had only shared it by request, so far only two people have asked me for it. I will send it to you. I have it installed and working, and I’m waiting to hear back from the other two. Give me a few minutes to try to gather it together.
The setup I currently have, has tensioners that get screwed to the extenders.
I had monkeyed around with something during the beta testing phase but I never installed or tested it. If I do ever do that, I will try to post what I find out. With the LR4 it’s a bit harder to “over engineer” such a solution because of how the printed YZ assemblies are.
:face_with_monocle::thinking::face_with_monocle::screwdriver:
OK, here you go: now on Printables:
